Results 1 to 5 of 5
    Croydon
    how to cut up a body shell...101
    Hi gang,
    So has anyone ever cut up a body shell before? I'm breaking the car down and wanted to see which bits I should chop up incase people want spares in the future...
    Plus it will be fun to do
    Trader
    Nocturnal Developments
    Haz's Avatar
    Re: how to cut up a body shell...101
    surely if the shell is that bad to break it the usual rough bits are bad on that too?
    is the car fully stripped?
    is it a sunroof model?
    poss roof, front panel, full sills.
    tbh there isn't much worth chooping off as each car has similar rough areas and most will want to replace with new, kts mainly crash damaged that it would be of use.
    i'd suggest using the right tools too. i asked my cousin to chop one in half a few years back so it could be lifted onto a trailer. came back a while later and looked like he'd used a tin opener. said he could find the grinder so used a pick axe!
    Kent
    Wind screen surround if it's any good and not holed.
    Croydon
    bugger meant to put the in the 5 phase 2 bit
    Trader
    Haz's Avatar
    oh in that case, nah scrap it
