Results 1 to 7 of 7
    burton on trent
    worn locks
    My r5 locks are all warn and any key, with a little force unlocks it. Due to this im looking on ebay for a r5 breaking to replace all the locks (apart from igniton with). Will campus locks be the same, and is there anything i must be wary of when swapping the locks over. Regards Damian
    Apr 2002
    Re: worn locks
    The gt turbo uses lightweight locks, whereas the Campus uses heavier ones, as it's not as fast. I believe the GTX and the Monaco also use the lightweight versions. All other models use the same heavyweight ones as the Campus.
    Raiders however, use a totally different one altogether. They're ultra rare, only 1000 sets ever made
    If you use the heavyweight version, be sure not to drop them on your toes while you're changing them, unless you're wearing steel toe-cap footwear.
    burton on trent
    Re: worn locks
    haha, you serious, i never imagined they would of gone into making lightweight version of the locks, ah well ,
    Trader paul b's Avatar
    Jul 2002
    Re: worn locks
    all R5 locks are the same ....
    only the ignition lock has changed ,but can be made to work using a bit of nouse
    burton on trent
    Re: worn locks
    ah ok, crazy , completly diff answers :P , dont need to swap ignition ,
    felixstowe
    Re: worn locks
    lol to bills reply.
    think this might give it away a bit about the locks
    The new Bill J
    Village Idiot
    Re: worn locks
    Very harsh Bill.
