Results 1 to 31 of 31
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    VNT Setup.
    Afternoon all.
    I have been fiddling off and on with my VNT for a short while now.
    I can either get
    a) upto 10psi @ 2000rpm with the rest following around 4000rpm ( total - 18 psi ish ) The car feels nippy at the upto 10psi but feels flat at anything over it
    b) it working like a t28, nothing then bang at 18psi and 4000-4500 rpm.
    Neither as you appreciate are ideal.
    From what I can work out I either have the duty at below 70% or above 80% but I cant find the sweet spot.
    Any ideas what to do ? For reference I have the 18psi dialled in with actuator rod length and the "stopper" ( the small grub screw ) is right at the top stopping the rod from going touching the body of the turbo
    Re: VNT Setup.
    you still not got ot setup get the car down here and i will get my chaffeur aka 5tevel to drive it for me and I will set it up for you properly matey
    Oct 2009
    Doncaster
    Re: VNT Setup.
    I thought I did have it setup. Went it in it after the megane and it didn't seem quick. Felt kinda flat.
    Re: VNT Setup.
    VNT shouldn't be flat matey, so when you first getting sign's of boost rpm wise?? and when is it at it's full boost level rpm wise??
    mine was 2300rpm's started to boost and full 24psi boost @2800rpm's with 1psi max spike as soon as you hit that full boost limit it should be constant on acceleration and not differ so it may feel flat as no more boost coming but you hit full boost so quick and you should be off like a rocket.
    Doesn't sound like you have the actuator set correctly, grub screw setting sounds ok aas you have boost around 2000rpms' shorten the actuator arm a tad
    Oct 2009
    Doncaster
    Re: VNT Setup.
    Boost is starting to come in around 2000rpm , getting to 10psi sharpish , but then not going anywhere.
    I cant get the rod any shorter. Its right at the very top !
    Were you boosting with a short rod , or via bleed ?
    Re: VNT Setup.
    I was using AEM electronic boost controller actuator was @18psi remainder was boost controller
    Loosen the rod a couple of turn's and tell me what effect it has?
    Oct 2009
    Doncaster
    Re: VNT Setup.
    Will do - working this week, so will have to try thursday.
    Oct 2009
    Doncaster
    Re: VNT Setup.
    Couple of turns ( so around 10mm "looser" ) and I am still getting alot of spike, and not a lot of boost.
    Ill upload a really crappy video in a second.
    crappy video.
    AFR are stable , boost goes upto 18-20psi ish ( hard to hold phone on my private road and drive )
    instant upto 10, crawl to 18-20, mad spike and settle. Its just so bloody slow at pulling boost.
    Lengthen the rod again ?
    Re: VNT Setup.
    crappy video.
    What actuator you got on the VNT ?, that's a pretty pathetic build up of boost for a VNT, should be a few 100rpm's of boost build up max and then just constant full boost beyond the rev limiter. I can't see why it's rapid to 10psi and sluggish beyond unless the Vanes are sticky / stuck or it's crap actuator.
    What effect did lengthening the rod make??
    Oct 2009
    Doncaster
    Re: VNT Setup.
    Its a standard one for that type of VNT AFAIK ?
    Looks identical to this one below
    Lengthening the rod ( I havent since the post above ) didnt make a great deal of difference. Lengthen again ?
    Re: VNT Setup.
    Were does your actuator take it's ref from?? in otherwards were does the other end of the vacum line go??
    Not the best vid but listen to how my VNT spools ok I haven't revved it hard or given it full beans but it's gone from no boost to not far of full boost in no time
    Oct 2009
    Doncaster
    Re: VNT Setup.
    Quote Originally Posted by Finch View Post
    Carb - usual POR as normal turbo. . . .
    Non-member DaveMayGTT's Avatar
    Fareham
    Re: VNT Setup.
    Is it possible you got a boost leak? Weak jubilee or something so by 10psi or so it starts leaking? seems a bit unlikely I know
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Re: VNT Setup.
    i struggled to get over 10psi when my DV diaphragm split.
    Oct 2009
    Doncaster
    Re: VNT Setup.
    no DV on this - and no boost leak. Holds 20psi when it eventually gets there.
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Re: VNT Setup.
    I don't really get VNT turbos despite having a pair on my Audi S4, but shouldn't you be shortening the rod to make the actuator work harder to open the waste gate?
    Ross
    Oct 2009
    Doncaster
    Re: VNT Setup.
    On a normal turbo yep.
    Non-member allanr5gtt's Avatar
    Dec 2008
    the carport
    Re: VNT Setup.
    i think the length of the rod is the (boost) pre load and the grub screw is the way the vnt kicks in ( vanes angle)
    Oct 2009
    Doncaster
    Re: VNT Setup.
    Allan , you are correct.
    Re: VNT Setup.
    Longer actuator rod equals more boost to much length and it will overboost so its a case of fiddling and finding the sweat spot
    Oct 2009
    Doncaster
    Re: VNT Setup.
    From what I read its to do with duty %.
    Below 70% it feels flat , above 80% and there is too much turbulence and causes mental spikes ( what I have )
    Fareham
    Re: VNT Setup.
    Doesn't mean the turbo isn't kicking out 35psi? On an old turbo I used to get to about 10 then struggle to get to 15 but would then hold it. Had a split intercooler.
    Re: VNT Setup.
    Get a proper turbo on there lad
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: VNT Setup.
    Quote Originally Posted by DaveMayGTT View Post
    Pressure test the boost system, I bet you have more than one leak...
    Fareham
    Re: VNT Setup.
    I probably should have just said that
    Oct 2009
    Doncaster
    Re: VNT Setup.
    Can now smash and hold 18psi.
    Just goes no where ...
    18psi on the gauge. Just does not seem to push
    Sep 2009
    meath
    Re: VNT Setup.
    still no joy on this?
    Oct 2009
    Doncaster
    Re: VNT Setup.
    It's getting tere. I have worked out the grub screw controls when and how boost comes in.
    Short thread below the housing = early boost, big spikes
    Long thread below = late boost low / no spikes.
    Been working 80h+ weeks so had no time to play
    Sep 2009
    meath
    Re: VNT Setup.
    ouch thats rough! was that the one you were offering?
    Oct 2009
    Doncaster
    Re: VNT Setup.
    Yep.
    I want it to be more raw , as in old skool, lag then bang.
    Thing I found with the VNT - although it makes the car quick it looses some of its old skool appeal. I have my r26 for cross country no nonsense turbo fun , i want hooligan style lag with my other toy.
    Sep 2009
    meath
    Re: VNT Setup.
    can you pm me pictures and all the stuff you've found out about it? would you be interested in a swap of a gt28r?
