Results 1 to 10 of 10
    Apr 2011
    Netherlands
    Valeo greenbox with Helix paddle
    what's the max power people used this clutch with?
    i currently have it in my f7r turbo on 7psi (no idea how much power it has) but i'm going to upgrade and trie to get at least 280hp.
    want to know how far i can go or if i have to buy a stronger clutch already...
    Non-member Coops's Avatar
    Re: Valeo greenbox with Helix paddle
    I ran that setup, slipped over 12psi, so I changed the cover plate for the helix one to match the 4 paddle clutch already in there and it was and still is fine at 17psi odd
    Apr 2011
    Netherlands
    Sorry, i made a typo. 10psi atm...
    But if i want to make it to 280 i deffo need a helix cover?
    Anyone have experience with how much the Helix can take?
    I wouldn't say defo, but in my application the valeo didn't have the clamping force even with the paddle friction plate, so I had to rip it apart and swap out for the helix
    I ran 21psi for a few days a couple of years back, it took that no problems, but as said that was for a very limited time before I dropped back to 16psi
    Depends on how lucky you are, I was still running the valeo green box clutch and 15psi , so im guessing the Helix clutch should cope fine for a lot higher.
    Apr 2011
    Netherlands
    well i already have first dibs on the clutch of Mikey so that's going to be alright. guess i'll find out how far i can go with it
    norwich
    302ftlb no slip on 215mm single 6 paddle plate
    Apr 2011
    Netherlands
    with greenbox cover? a well, already bought a complete Helix jobbie now
    Non-member JP Racing's Avatar
    Apr 2009
    Ely
    I think handy was running the helix cover and 6 paddle clutch but it is in the 215mm clutch and flywheel from the 172
    Apr 2011
    Netherlands
    TY
    i think the complete 200mm Helix package will be up to the job
