Results 1 to 32 of 32
    Feb 2012
    Nottingham
    Discs and pads
    Hi guys
    Since I can't drive it Iv got a couple of hrs spare has anyone got the link to fitting new discs and pads to the rear? They already have bearings in.. Cheers
    Non-member 5 turbo's Avatar
    Mar 2011
    Re: Discs and pads
    Undo two bolts at back of calipers to remove carrier. Unclip rattle springs. Remove retaining clip and slide out right angled bar which holds pads in. Then remove pads. Remove cap over nut in centre of disc, undo nut, remove disc. Fitting is reversal of that. Would be easier undoing the nut before removing pads as will stop disc from spinning. Haynes manual is always easy instructions with pics as well
    Feb 2012
    Nottingham
    Re: Discs and pads
    Think this is a job todo today Iv had them for weeks now.. Mrs and baba off out for the day suns out no rain today please.. How long you think?
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Re: Discs and pads
    Remember with rear calipers the piston has to be wound back not just pushed back. Should be clockwise while applying pressure.
    Feb 2012
    Nottingham
    Re: Discs and pads
    Cheers bud I have the bible next to me and can always refer on here.. Only done them once before about 6 years ago on another 5 I'm sure it will come back to me
    Feb 2012
    Nottingham
    Re: Discs and pads
    So quite easy really just need to have them bled I can't be arsed with all that
    Scabby old
    http://s1170.photobucket.com/albums/...er_media_share
    Nice and new
    That's it for today football calls...
    Feb 2012
    Nottingham
    Re: Discs and pads
    So my rear bearings gone I only had it on for about 600miles.. Strange it was already fitted onthe disc when I bought them.. Perhaps I didn't grease them enough off in the garage to put my old discs back on as it's knocking bad.. The strange thing is I can't tighten them anymore and the wheel moves a couple of mm.. Could they have cal lapsed?
    Re: Discs and pads
    Or you could have a problem with the shaft from suspension arm which the disc slots on to. This will have the same effect if its worn out
    Feb 2012
    Nottingham
    Re: Discs and pads
    Oh dear is that a big job? As I wanted to go to scoffs if it's on that is.. Will whip it off and have a look see what's up
    Re: Discs and pads
    That I dont know as I put brand new discs on my rear and have the same issue with it moving had same with fronts as well. Not replaced the rears as they only move a tiny amount but the will gradually get worse. As for the job, I am thinking its easier to replace rear axle then trying to remove the suspension arm off and replace. Dont think you can just remove the shaft which the discs sit on but somebody might say otherwise
    Feb 2012
    Nottingham
    Re: Discs and pads
    Blinking ek I hope it's not that then will get off my backside in a minute.. Been up since 4am as the lil one is teething it's since I slammed on the brakes last week.. But I guess these are old ladies now
    Non-member GTphil's Avatar
    Re: Discs and pads
    I have had issues with bearings in the not to distant past, had the bearings pressed in less than 1k later ****ed! This continued to happen with the cheap pattern bearings, spent the extra cash on some genuine Renault ones and 5 years later they are still going strong.
    Had a similar issue with with cheap bearings on my 2004 fiesta also.........
    Feb 2012
    Nottingham
    Re: Discs and pads
    Well I hope that's it think I only paid £50 for the grooved discs with bearings off a member they were new but I don't know if they are a good quality brand..
    Re: Discs and pads
    Might have damaged the bearing when pressing them in?
    Feb 2012
    Nottingham
    Re: Discs and pads
    They were already in Brigsy it's since I slammed on the brakes last week im about to whip it off so will report back I hope it's just a case of putting my old ones back on I only changed them to put grooved ones on so we should be golden
    Feb 2012
    Nottingham
    Re: Discs and pads
    Well Iv took the wheel off started to undo the nuts on the carrier and they both was a good couple of threads loose not even finger tight?? I know I tightend them as I'm daft but not that daft is this normal or should I carry on and see if it is the bearing and the vibrations have made it loose?? I tell you what after some of the driving Iv been doing lately its scary to think they were loose
    Feb 2012
    Nottingham
    Re: Discs and pads
    Nope right first time.. Bearing had cal lapsed... Stuck my old disc on for now and everythings sweet.. Check your bearings Bigfoot it might just be that bud..
    Re: Discs and pads
    I hadn't even driven it or put it on the floor when it was like that, but will take a look when I will be working on it next.
    Feb 2012
    Nottingham
    Re: Discs and pads
    think you might be right Bigfoot Iv been for a drive and it's the same.. There's Definatley movement on the back wheel still even changed the wheel for another and still the same.. There's four like star shaped studs wonder if you can change the stubs? Anyone?
    Sep 2005
    Parkgate Cheshire
    Re: Discs and pads
    I went through 3-4 bearings from gsf, cheapest crap ever, used euro car parts one and its been on 2 years so far(compared to around 6 months for the gsf ones) i agree on the renault bearings but for me at work i can get 4 bearings to one renault one.
    Sep 2005
    Parkgate Cheshire
    Re: Discs and pads
    if the old discs where ok? and the new bearings arent then im geussing its the new bearings giving issue, its unlikely to be the rear stub axle.
    Feb 2012
    Nottingham
    Re: Discs and pads
    Well a happyish ending turns out when I did that stupid skid the other day I didn't just kill the front tyres I killed the back aswell that one stupid street race has cost me about £300 in tyres.. But atleast the knocking has gone.. Back with the moriettes for a while..
    Sep 2005
    Parkgate Cheshire
    Re: Discs and pads
    That must of been one hell of a skid....
    Feb 2012
    Nottingham
    Re: Discs and pads
    Just a bit bud
    Sep 2005
    Parkgate Cheshire
    Re: Discs and pads
    woohooooooo looked exciting
    Feb 2012
    Nottingham
    Re: Discs and pads
    It's not true you don't see your life flash before you just cars walls and the whites of the old *******s face that decided to do a you turn.. I know I was going to fast but thankfully no one got hurt.. Just my wallet.. On a good note my brakes work well
    Sep 2005
    Parkgate Cheshire
    Re: Discs and pads
    It looks like theres only one set of skid marks, i bet your bias valve could do with some adjustment.
    Feb 2012
    Nottingham
    Re: Discs and pads
    My fronts were nearly flat the backs are slightly flat but enough to hear it I'd say I was top end of 3rd to a standstill.. The 5 fish tailed like madly if it had been single lane I doubt I would of got away with just tyres
    Member Thundercat's Avatar
    Re: Discs and pads
    With regard to bearings, i've tried many brands, Renault and BRT seem to be the only good ones on the market. All so found that some new rear discs are over bored causing loose bearing fitment.
    Non-member Logg's Avatar
    Re: Discs and pads
    Quote Originally Posted by 5279 View Post
    Good shout with BRT Looks like they use cylindrical bearing as opposed to ball bearings. Think ill give them a call Monday and check.
    Re: Discs and pads
    Luckly for me theres a BRT trade counter in Lincoln, only ever had one bad rear bearing off them and they replaced with no problems.
