Results 1 to 30 of 30
    Non-member Misky's Avatar
    Oldham, Greater manchester
    What gauges do you have?
    What gauges have people got in their 5's?
    I currently have a boost gauge where the clock should be.
    I was thinking of getting a water temp gauge aswel.
    Re: What gauges do you have?
    I have replaced the center vents on the dash with one of those chrome CGB 3 x gauge holders 9pain in the arse when sunny) I have a psi boost gauge, a dual oil pressure and water temp gauge, and the other I did have an XD-16 AFR gauge, soon to be replaced with EGT gauge.
    Non-member Mudslinger's Avatar
    Feb 2003
    a good water temp gauge is a good investment m8
    check out the dual oil pressure/water temp SPA gauge ,thats what im using . ive also got the spa rev counter/speedo , and a dual boost /exhaust gas temp still to hook up .
    Sittard, Netherlands
    AFR, water temp and oil temp:
    I have 2x dual SPA gauges located on the A pillar. I have a boost/charge temp & oil pressure/water temp useful bits of kit but more to worry about!
    Non-member BriC's Avatar
    Dec 2005
    Boost gauge, Water temp, Oil pressure
    In the van i have boost & oil pressure. Might fit an oil temp gauge soon.
    My gtt has boost, oil pressure & voltmeter.
    Feb 2003
    i think id like an oil temp gauge in mine just to see whats going on , its running to cold i think , water temp never went above 70 , need to change the low temp thermostat me thinks just to allow the oil to get a bit warmer , normall running water temp should be in the 80's i think ??
    Quote Originally Posted by Mudslinger View Post
    Normal water temp during cruising is in the low 80s. Oil temp should be in the low 90s when cruising...
    I have a low temp thermostat and still have these temps, so I don't know why yours are so low. Where did you fit the water temp sensor? Mine is welded into the head...
    Feb 2003
    Quote Originally Posted by jantheeven View Post
    the temp sensor is plumbed into the 1 of the pipes going to water pump ,
    the way the water circuit is done is slightly diff to normal 5 ,but it just seems super cool , also having the seperate oil cooler helps keep the water temp down , the fan comes on about 86 but very rarley does it get that hot unless stationary for a lengthy time, so its something im going to look at soon , normally you wouldnt be complaining about a 5 gt turbo running to cold
    Today i have been getting running temps of 62c coolant temp hasnt risen above 70 for ages because of the freezing weather!
    Non-member ollyhock's Avatar
    STOCKTON
    Non-member MR TURBO's Avatar
    bristol
    Quote Originally Posted by ollyhock View Post
    Looks sweet
    Non-member dgdogz's Avatar
    the land of scots
    i got a
    boost in a pillar
    water temp
    oil temp
    volts
    Non-member markey b's Avatar
    Bury St Edmunds
    i got a few...
    AFR, manifold boost and water temp on the rollcage a pillar bit
    then carbtop boost, oil pressure and voltage in the clio centre gauge pod
    Aug 2004
    Double din consols FTW, ps i have 2 for sale in the classifieds!
    Boost gauge
    Oil pressure/temp gauge
    Volt metre
    Will have an AFR gauge also at some point...
    I dont know where to mount anymore gauges?
    Cant say im a massive fan of pillar pods, but I dont want to remove my centre heater oulets. (excuse the red fleck, only temp ) Any ideas?
    Dec 2005
    Double din centre console, and then put 3 gauges in one of the din slots?
    Non-member Amber5GTTurb's Avatar
    South West/Somerset
    I've got on eof those too but stainless - but i've only got a boost gauge at the mo. Want to get an oil temp and pressure as well
    Bury St Edmunds
    put the gauges in ya cage
    I spy a pillar pod on the passenger seat, markey!
    Guess i could always paint it to blend in.
    Bury St Edmunds
    yeah, sold it on flea bay.. it was painted in bumper grey and matched the interior perfect!
    in fact.. pic:
    Nice one!
    Was one of them universal jobbies?
    North West Area Rep LukeRobbo's Avatar
    Nov 2008
    Cumbria
    in fact.. pic:
    That looks really good.Where did you get the polished stalks?
    the land of scots
    yeah 2nd to that
    them polished stocks are loveeeeeeely
    Non-member OUTLAW's Avatar
    ENGLAND
    if you dont mind, i`m gonna have to 3rd that...lov`in those chrome stalks, where did you get them?
    Bury St Edmunds
    member on here (i think) called big g... had em in my old car too.. they pimp! lol
    pod was made from a universal one, os8472 actually made it, i just painted it grey
    Non-member gttjames's Avatar
    Cambridge
    good place to put them would be in centre blowers as they allways blow cold anyway
    the land of scots
    bumpy bump bump
    any of you fine chaps able to point me in the direction of those chrome stalks???
