Results 1 to 24 of 24
    Non-member SirSamuelOfBuca's Avatar
    Jan 2012
    Whittington
    fumes in car
    Any ideas why fumes are coming in to car? Thought it was down pipe but tightened it up.
    Boost feels a bit weak and at 2000rpm in 4th car was very loud today. Hmmm :-(
    Classifieds Moderator
    Mar 2004
    Re: fumes in car
    carb base coming lose? crack in carb, fpr lines...
    Tipton
    Re: fumes in car
    youve got incar boost and are taking the feed from the centre port in the middle of the carb ( the one that is mixing air with fuel)
    Jan 2012
    Whittington
    Re: fumes in car
    Ah sparkie ur a genius lol. I bet that is the problem ;-). I dont know where else it goes :-(. It's between carb and actuator at the moment.
    I feel my engines knackered though it's never felt right since I've had the car. It's getting me down a bit now :-( power is terrible. Feels on the verge of blowing up and I don't run much over 10psi.
    Tipton
    Re: fumes in car
    Quote Originally Posted by SirSamuelOfBuca View Post
    how can something 'feel' like its gonna blow up.
    5's generally do or dont blow up.
    what r ur symptons?
    Jan 2012
    Whittington
    Re: fumes in car
    Well sounds funny on start from cold,rattley maybe. And power feels weak. On boost their feels like the engine has nothing to give, which makes me wary about givin it some (blow up an exaggeration perhaps!).
    Was not in good condition when I brought it and in hindsight I should of waited for something better. I've changed alot of things. On 3rd drivers side drive shaft now. I have replaced all that side of car now suspension mounts, ball joint etc so hopefully will be ok.
    I'm not mechanical at all. But have Learnt alot the past few months! I check water and engine no mayo but I still have a feeling something is not right. Checking receipts it's had a lot of engine bits (pistons, head gasket, big end bearings). But up to 5 years ago so doesn't count I guess.
    I've never been in a 5 other than mine so have no comparison.
    Sorry for essay! :-) just annoying when you spend alot of time on something ;-)
    Jan 2012
    Whittington
    Re: fumes in car
    Btw i have engine bay boost controller and boost gauge in car connected to carb - actuator.
    Would it be the gauge that smells? As it only seems to get fumes when I get some boost? Cheers :-)
    Tipton
    Re: fumes in car
    u could have leak in the pipe to the aei, i'd have to have a look.
    what cam u running?
    Jan 2012
    Whittington
    Re: fumes in car
    It's standard cam as far as I know.
    I don't even know what aei is haha will google!
    Tipton
    Re: fumes in car
    pop over anytime, ill have a butchers.
    aei is the renix ignition module in your scuttle tray.
    Non-member car.crash's Avatar
    Aug 2006
    Re: fumes in car
    Is the large rubber seal fitted along the scuttle area?
    Jan 2012
    Whittington
    Re: fumes in car
    Cheers sparkie. I'll get over the pit this weekend and fit my afr to downpipe.
    Jan 2012
    Whittington
    Re: fumes in car
    hmm
    get a funny noise from right hand side of engine bay when i put foot down. had this with t2 fitted and its worse with gt28. like a rattle/metal noise. sounds like carb area not sure. maybe leak?!
    I have another carb might try and fit it. is it a simple job of disconnecting and unscrewing replumbing?
    Farnborough
    Re: fumes in car
    Does it sound like tappets ? is so could be the manifold gasket. Have you checked there is nothing loose that could be rattling around ?
    Jan 2012
    Whittington
    Re: fumes in car
    i had my tappets done so they are quiet now.
    Hmmmm ill give it a good going over this weekend and give it a blast see if I can record the sound.
    Cheers
    Tipton
    Re: fumes in car
    hmm
    is the metal plate that covers the inlet/exhaust manifold actually bolted to the inlet manfold? - its under the carb- next to the rocker cover.
    if its loose it can rattle.
    Re: fumes in car
    I developed a very good 'spider sense' when driving my GTT's. Sometimes you can just tell there's something not quite right. Difficult to put into words but I bet there are other members on here that have the same or similar.
    Jan 2012
    Whittington
    Re: fumes in car
    I hear that many squeaks/rattles/clunks i have no idea what any of them are haha
    Jan 2012
    Whittington
    Re: fumes in car
    Sparkie, I have to go to oldbury in the morning n tipton is not to far away if your free would you be able to take a peak? obligatory beer tokens or something for your troubles of course
    just want someone who knows what to look for to give it a look over. state of it is embarrassing after seeing Carlos on heres raiders last weekend!
    Jan 2012
    Whittington
    Re: fumes in car
    I can tell there is something not right. a renault espace blitzed me off the lights the other day haha
    Tipton
    Re: fumes in car
    what time you thinking?- ive gotta go merry hill tomorrow morning.
    Jan 2012
    Whittington
    Re: fumes in car
    Oh dear haha I've just got back hateful place! Well I'm going to my mates garage to change
    My brake pads will be there till 12 probably so after then? If ur busy then don't worry mate but I'd like to book you some time haha! :-)
    Tipton
    Re: fumes in car
    give me a bell or a text to see where i am, unfortunately im holiday shopping, so may be a while
    Jan 2012
    Whittington
    Re: fumes in car
    Ah cheers can you pm me your number. Off out the country? I'm sick of being rained on :-(
