Results 1 to 13 of 13
    Non-member ren_5hitbox's Avatar
    Jan 2012
    Please help :,(
    Someone please help me, took my 5 to work today and everything was as normal. Got home chilled out for a bit went to use the 5 again and no electric at all!!! No lights no noise turn the key and nothing! Fuses all checked and fine, are there any other hiden fuses anywhere? Has anyone had this problem before???
    Thanks
    Farnborough
    Re: Please help :,(
    Have you checked the battery is not dead ?
    Feb 2012
    Nottingham
    Re: Please help :,(
    Dose your ignition lights come on? Start with the main connections to the batteries.. Mine touched and burnt the negative off..
    Jan 2012
    Re: Please help :,(
    Thank you both for getting back to me, really appreciated, checked battery nothing is lighting up not even the ignition
    Farnborough
    Re: Please help :,(
    Just a guess here. Perhaps the ignition switch is faulty. Does the interior light come on when you open the door as that works regardless of the ignition. Think the hazard lights may as well but cannot remember, been a long time since my 5 was on the road.
    Non-member GTphil's Avatar
    Re: Please help :,(
    I had this once and it was the battery, sometimes they die a sudden death!!
    I was convinced it was something else, went through loads of different things spent almost 2 hours looking for a "fault"
    Tryed another battery and hey presto!
    Non-member SirSamuelOfBuca's Avatar
    Jan 2012
    Whittington
    Re: Please help :,(
    I had same was battery :-/
    Hope it's that simple gl mate!
    Jan 2012
    Re: Please help :,(
    Well my mate popped over who is a marine so has a good idea with engines etc, took out a few wires cleaned them off jumped the car and the old gal started up he said the battery is dead too, thanks everyone for getting back to me
    birmingham
    Re: Please help :,(
    Quote Originally Posted by ren_5hitbox View Post
    Thanks
    always remember though mate no battery no power,but a ovious sign can just be no interior working,or when you turn the engine over and no noise/click or nothing then you knowbatteries can be a strange one.good you have it sorted anyway
    Jun 2010
    Re: Please help :,(
    check the anti perc fan relay, mine stuck on last year and would have drained the battery if i hadnt heard it still running when i went to answer the door about 15-20 mins after shutting it off
    Non-member Hoolio's Avatar
    Wallingford
    Re: Please help :,(
    Quote Originally Posted by Phoenix Autosport View Post
    When it's warm mine will run for half an hour or so
    Jan 2012
    Whittington
    Re: Please help :,(
    Above two posts. No gtt is the same haha
    Jan 2012
    Re: Please help :,(
    I do feel silly now for only having a dodgy battery! New battery bought and the car is sound but usually with any other car I've ever had I've always seen warning signs that the battery was going to die, so strange but in the flip side it was great to find such an easy fix great to be in the rtoc though because everyone is so handy and eager to help out
