My car has got 8.5mm spitfire leads just fitted a 90degree dizzy and they fall off would I be better off buying standard leads
ive got some blue 8.5 magnacor leads for sale i had them on my 90 deg dizzy cap and never came off.
You got a picture and price cheers
can you send a email address and ill send you pics.
Standard boughicord leads are the best mate
Wheres the best place to get them
is this your issue....
https://www.rtoc.org/boards/showthread.php?t=27053
you can either put wd40 on the plug caps at the end and slide them further down the leads so it will go on easier, or use thinner leads like said
Can't believe how much the standard leads are its around £80 for leads and king lead
The king lead is shockingly expensive like, i just used a part worn one
I might just bite the bullet and get them
That's on gt turbo spares web site
ive got some standard ones aswell.
Everybody i know who has bought magnecor leads has had one fail at some point, no matter what make of car. Standard leads last for miles longer.
Hmmm, In ten years of racing, sprinting etc in everything from a 1.6 nova to a 400Hp rx7 I've used them on every car i've owned/run and never had a lead related ignition fault, I can see the point in a mint oe car but I suppose it's all down to personal choice.. The fact that they swap them striaght out if youve got a problem (and a receipt) says it all for me...
I have to say my Magnecor leads have been excellent, I've had them about 8 ish years now and they're as good as new. I used to have standard leads and they were also very good but looking a bit tired hence why I replaced them.
I say buy whatever is cheapest out of the 2!
I think it's more back in the day when 'tuner BS' indicated uprated everything when in fact in more than 1 case (proven) OE parts were up for the job and cheaper. Why pay extra for fancy coloured leads when OE items worked just as well.
