Page 2 of 2 FirstFirst 12
Results 51 to 76 of 76
  1. #51
    Dec 2004
    Aylesbury
    Re: Questions
    Quote Originally Posted by GaryS View Post
    Next questions
    Rev counter, ive read it connects to pin 8? on the clocks but which of the 3 plugs is it on the dials?
    Also i think i just boiled my water thermo must be stuck.
    It takes a good few cranks to get it started is that because i anit changed my pump yet?
    Thanks.
    Connect the wire from the Volvo plug to the rev counter wire on the original AEI unit plug. Thats how i've done rev gauge before and works fine
  2. #52
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: Questions
    Follow the train tracks to the tacho that's the plug. Get a new stat my first one opened up when in a pan of boiling water but not in kettle water. You need a bigger pump golf gti pump good for 18psi.
  3. #53
    Non-member GaryS's Avatar
    Fleet, Hampshire
    Re: Questions
    Sorted the cooling system, fitted a new stat and it still boiled out the header tank. So i took the top rad hose off and had now water there so i pumped it loads of times and now its sorted.
    The next thing is that the idle is all over the shop what can i do to try and fix it?
    Oh and here is a quick pic
  4. #54
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: Questions
    Looks really good mate, any pics of how you've mounted the ECU?
  5. #55
    Fleet, Hampshire
    Re: Questions
    Cheers
    They are not mounted yet but they are in the shuttle area and will be mounted on some black perspex painted black, thats the plan. I have the chrome shuttle covers aswell to cover it all up and going to stick the 'volvo 480 Turbo' badges on the covers.
  6. #56
    Re: Questions
    Looks good matey. In regards to the idle you don't have a dump valve fitted or bleed valve basicly anything that means the engine can get un-metered air in?
    Are you on std injectors etc...?
  7. #57
    Fleet, Hampshire
    Re: Questions
    Nope no dv or anything fitted and I'm on std injectors. Dirty injectors?
  8. #58
    Re: Questions
    How bad is the idle? Are you letting it get up to temp? Could just do with a good blast to clear everything out.
  9. #59
    Fleet, Hampshire
    Re: Questions
    Just sounds if its missing, trys to cut out. im letting it get up to temp and when the fan comes on it nearly stalls itself.
  10. #60
    Re: Questions
    What about when you turn lights on etc... Sounds like its a voltage drop prob then. Where is the maf placed?
  11. #61
    Fleet, Hampshire
    Re: Questions
    When i tested my lights i dont think the voltage dropped, i will check when i fix it from my melted wire and smoke
    My maf is just basicaly bolted on the turbo, does that make a difference?
  12. #62
    Fleet, Hampshire
    Re: Questions
    Oh and ive tryed Marks way of the rev gauge and i didnt work ? Whats another way or the best way to do it?
  13. #63
    Dec 2004
    Aylesbury
    Re: Questions
    That should work, its how i've wired up a few 5's before and they work
  14. #64
    Dec 2004
    Aylesbury
    Re: Questions
    Yes that will make a huge difference, try mounting the MAF as far away from the turbo as possible
  15. #65
    Re: Questions
    As mark says get the maf away from the turbo as the spinning blades will screw the maf signal up.
  16. #66
    Fleet, Hampshire
    Re: Questions
    ok found my idle prob on my charge cooler there are 2 bolt holes that go through into the cooler and i forgot to block one up so had a open hole thus bad idle ooopps.
    just need to sort my melted wire prob now help.
  17. #67
    Fleet, Hampshire
    Re: Questions
    Right, do i need a different starter motor for my car i just brought a new gtt starter but that sounds like its grinding is there a difference with the volvo starter?
  18. #68
    Re: Questions
    Yeah you need a starter for the Volvo or a Clio. Do you have the 215mm flywheel? If so the starter needs more teeth. If you have the 200mm flywheel you may be able to use the gtt starter and it may need some adjustment but I don't know.
  19. #69
    Fleet, Hampshire
    Re: Questions
    Sorted moved the pin to the other hole and stuck my volvo starter on that i had off the original engine
    Anyone need a new gtt starter
  20. #70
    Re: Questions
    been there.
  21. #71
    Fleet, Hampshire
    Re: Questions
    Hello again people.
    My car is running abit funny not quite right, the revs rise and drop every 5 seconds or so, what can i check?
    Also when my cars running in my garage it stinks of petrol.
    Cheers.
  22. #72
    Re: Questions
    Hello again people.
    Cheers.
    Icv
  23. #73
    Fleet, Hampshire
    Re: Questions
    would the icv make my car really stink of fuel while its running?
  24. #74
    Fleet, Hampshire
    Re: Questions
    Hello, got my car up and running again and it Stinks of fuel, i have now fitted a AFR and on tickover its reading 22.9 or something! and when i rev it up abit it drops to 16.6 ish. Please help as i have a mot tomorrow
  25. #75
    Leeds & South Yorkshire Area Rep
    Loose Bolts Tuning
    Robbo's Avatar
    brighouse
    Re: Questions
    check the fuel pipe connections as mine worked loosei ended up getting proper fuel pipe clamps and not using jubilee
  26. #76
    Fleet, Hampshire
    Re: Questions
    mine are all new and no leaks
