Results 1 to 21 of 21
    walsall
    cgb motorsport
    i phoned him yesturday asking him where he gets his lightened and balanced flywheels done as i had a flywheel which needed balancing and if he could do it!
    he then told me he does not balance them!
    he gets them machined ie( the same amount taken off all round and they should still be balanced and then he sells them as lightened and balanced flywheels?
    has anyone used his flywheels and is everythink ok with them as that sounds alittle hit and miss ?
    Re: cgb motorsport
    the bloke i use to do mine shaves em down then he balances them after by shavin in certain places after weighing/ measuring them..
    Non-member r5 rich's Avatar
    Romford, Essex
    Re: cgb motorsport
    ctm is the place to get stuff done like this, they also give 10% discount to rtoc members
    May 2003
    Haslemere, Surrey
    Re: cgb motorsport
    Quote Originally Posted by bye_all_c_ya View Post
    if they are sold as lightened and balanced, then i'd assumed they'd been balanced
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Re: cgb motorsport
    Some flywheels I have had lightened and balanced have come back with small holes drilled in them to help balance them.
    Re: cgb motorsport
    Those small holes ARE the balancing
    Some places will just lighten them.
    Aug 2004
    Re: cgb motorsport
    Another good reason not to buy from cgb :-)
    Non-member Kenobi's Avatar
    Jul 2006
    Leicestershire
    Re: cgb motorsport
    Quote Originally Posted by ShopBoy View Post
    Now thats not fair.
    Non-member OUTLAW's Avatar
    ENGLAND
    Re: cgb motorsport
    Quote Originally Posted by Kenobi View Post
    Now thats not fair.
    i can only agree, bob has always pulled through for me, and is always really helpful, but you should always question, exactly what your buying and the condition. even from cgb
    Trader paul b's Avatar
    Jul 2002
    Re: cgb motorsport
    as long as the same weight is removed at the same diamteter from the centre..usually.no problem...
    a balanced flywheel CAN only be done correctly when supplied with a crankshaft and a clutch fitted and marked, its fitted and balanced in situe.......this should also be done after any other work done like a new clutch....as 2 will never be the same..
    just my opinion, shoot at will
    Member clee's Avatar
    Derbyshire
    Re: cgb motorsport
    That's very true Young Paul .You don't get your wheels balanced without tyres and valves now do you .
    walsall
    Re: cgb motorsport
    ive never had a problem with bob! top bloke
    but i was suprised to hear of the method used to lighten and ( balance ) his flywheels as sold on his website, when he does not balance them after!
    but makes sense if you take the same off all the way around it should be still balanced shouldnt it?
    as this method i can have done for free every day lol it was the balancing i was worried about as my dad is manager of a tool makers company
    and after knowing how he does it seems a bit pricey when its a 15 min job!
    Non-member tiff_lee's Avatar
    Glasgow/Lincs
    Re: cgb motorsport
    Now thats not fair.
    Perhaps not but to sell something as lightened and balanced when it is in fact only certain of being lightened is rather misleading and also not particulary fair.
    Re: cgb motorsport
    If that was the case then CTM wouldn't have spent £15,000 or whatever it was, maybe £5000, on a balancing machine.
    Ideally, each item should have it's own balance. So the crank first. When that's correct, then the flywheel is attached, complete with the three clutch locating studs, and done. Then the clutch over is attached to that and done and marked.
    Aug 2004
    Re: cgb motorsport
    I am sorry but selling some described as "lightened and balanced flywheels"
    That has not been balanced is clearly false advertising...
    I have brought many things of Bob and been happy but i dont buy performance parts of him... and there is a reason for that. But i wil keep that to myself and not share with other people.
    cheshire
    Re: cgb motorsport
    I always thought rods and pistons should also be balanced too.
    Non-member Barr's Irn-Bru's Avatar
    Jan 2006
    Glasvages
    Re: cgb motorsport
    Use a campus flywheel . Fit a Volvo clutch Convert to the Volvo soft pedal conversion ......
    But Carlsberg Don't do Renault 5GTT tuning, But If they did
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: cgb motorsport
    once you lighten a flywheel the balancing becomes much less important. you should also only ever be interested in crank and flywheel balancing if you're aiming for lots of rpm. otherwise, factory tolerences are fine.
    Jul 2006
    Leicestershire
    Re: cgb motorsport
    N00b question.
    Can this be done on modern cars?
    Dec 2004
    Aylesbury
    Re: cgb motorsport
    You can lighten and balance any flywheel from any car
    Non-member dgdogz's Avatar
    the land of scots
    Re: cgb motorsport
    i couldnt comment on performance parts from bob
    everything else ive had from him has been minted...good prices good guy good attitude jus good in all aspects if you ask me
    but IF
    hes selling stuff as lightened and balanced and its NOOOOOT then a small slap on the wrist should do it fine
    hahaha
