Results 1 to 9 of 9
    Feb 2012
    Head gasket?
    Pretty sure you lads know the biscuit better than the lads over on c16v so here goes
    Had my Hayward and Scott exhaust built today (very sexy) and on the way home I gave it slight death (not horrendous) and it started smoking heavily...
    Initially I thought the worst about everything but then later realised it had done a whole tank of coolant. Topped it up again, another hour it was empty again
    Plooms of smoke enough to make a smoke screen
    Runs a spesso 1.6mm metal gasket.
    Noticed the actuator bolts loose earlier too so the actuator would of had to move alot further before it opened the wastegate. I think its basically over boosted itself and got bang
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Re: Head gasket?
    Does it sound like its misfiring abit?
    Pressurising the coolant hoses quickly?
    Re: Head gasket?
    Does sound like h/g failure, not as if you could crack a liner as there are none
    Non-member 5teve L's Avatar
    RH12
    Re: Head gasket?
    Would think it's gasket related if you have smoke/vapour from the exhaust. If you were just loosing coolant I'd have said check for leaks.
    norwich
    Re: Head gasket?
    Quote Originally Posted by wag1 View Post
    what boost where you running ?and how long where you giving it deathand how high did the engine temps go
    the emerald ecu should have compensated , even if you where running slightly more than 11 psi at a guess? only thing it may have been running out of injector cc, not so goodlike been mentioned above, head of and inspect, prob only done the gasket, at worst cracked it or the block (between the headbolt holes, check the head with a steel rule and no more than 0.5 gap. you've got forged internals so a bit more resilient to damage, all though any heavy det will still trash them
    i run a mls gasket and uprated 12.9 tensile bolts ,the bolts you can get in the rtoc shop section, and re- bolt head down to 80-90nm if you want to be on the safe side, or if you've got a bit more cash,arp f4r head bolts share the same thread pitch/dia, but are longer, so you would need some 6mm high tensile spacer /washers,there good for 120nm , if you want to take it to the extreme bit over kill, but if you like to over engineer
    im guessing your boost controler is mechanical, an electro type with twin solinoid and built in overboost saftey would be a good investment, would stop any spiking and give you better control of the actuator also
    hope thats of some use wag 1
    Feb 2012
    Re: Head gasket?
    Pretty much all of the above
    My injectors were mapped at 283 and pretty much peaked.
    Im sure it ran lean and everything. Slight misfiring yes. Still drivable.
    Think its an engine out job. Im sick of the bloody thing to be honest. Been nothing but agro. 700 quid on a ****ing H&S exhaust thenthis happens.
    Purely because of the aftermarket cams and pulleys I wont attempt the job myself.
    I wont be too sad if its done the block.
    Thanks for the replys. Lads
    Sep 2005
    Parkgate Cheshire
    Re: Head gasket?
    Co test would prob be your best bet, make sure it has gone before you condemn it.
    Re: Head gasket?
    you can get a coolant tester die that you can add to the system id do all the cheap tests first, i pulled the head off my turbo 2 as i thought the head gasket had gone.......water pump belt come off foool!
    Non-member Coops's Avatar
    Re: Head gasket?
    sad times frank mate :-( but it does sound like you've done the H/G tbh
