Results 1 to 9 of 9
    Non-member SirSamuelOfBuca's Avatar
    Jan 2012
    Whittington
    diagnose problem
    I changed drivers side drive shaft 2 weeks ago. Now when I'm driving there is a whistling noise that speeds up and slow down with my speed.
    It started a week later. Can't check till Saturday hoping it can be ok to drive!
    Non-member jamie_8's Avatar
    Nov 2009
    reading
    Re: diagnose problem
    Sounds like it could be a wheel bearing issue..
    Jan 2012
    Whittington
    Hmm strange it's just happened after changing drive shaft oh well will change that the weekend! Lol
    Tipton
    might sound silly - have you checked your gearbox oil....?
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    gearbox oil also if you have a gaurd by the bottom ball joint or the dirt shield behind touching the disc.
    Non-member Eugein Offord's Avatar
    Nov 2008
    north surrey
    the nut behind the wheel??
    Jan 2012
    Whittington
    Quote Originally Posted by Tony Walker View Post
    Ye started quietly now it's a full blown squeak definitely could be this I'll try and check it now thanks.
    bracknell
    pull the inner gater back see if the joint still has grease in there
    Jan 2012
    Whittington
    It was nut behind the wheel. Took wheel off and had excessive play. It had started to undo the nylon part broke put some nut lock glue and tightened it back up.
    Cheers guys
