Hi gonna have a bash at the carb ,where can i get these parts from ? cheers.
or do i have to drill.
1.1mm ac jet
1.3 2nd stage
2mm needle valve
1.1mm ac jet
1.3 2nd stage
2mm needle valve
i think mike phase i 16 v turbo has the jets mate im not sure about the needle valve tho pm him he is your best bet
You could either get the ac jet from Mike or the 2.0 needle jet from german ebay, the 2nd stage is a non removable jet and is standard 1.0 so what you will need to do it buy yourself a micro drill set Do you have wideband AFR kit?
personally I would just buy some solder, micro drill bits, check the sizes of what you have in the carb now if needed solder the a/c jet up and drill out using micro drill bit to the correct size.
The needle jet as said can be purchased a 2.0 already from ebay or open it up yourself with the micro drill set just be careful and make sure it seals properly.
Thanks , yeah i have an afr gauge fitted .
2mm needle valve - http://www.ebay.co.uk/itm/Schwimmern...item5188c20372
is this what i want ?
http://www.ebay.de/itm/Volvo-Penta-S...item5192d5c485
Are there any seals to be replaced with changing these jets / Valve ?
its not long had a full seal kit so i wont be doing the whole thing.
im going back to my home made 2.0mm drilled one which sealed fine.
I believe this is right one for Solex DIS http://www.ebay.co.uk/itm/Solex-Schw...item2c57cf700f
