just wondering are all spark plug locating holes the same diameter.? would like to know as im going to buy a comp tester.
thanks.
thanks.
yup. all the same size....
There is a smaller one but then isnt that for motorbikes? When I bought my 'Gunson' comp tester it had an adaptor anyhow.
two sizes, you should get an adapter with it anyways.
I thought you meant on the GT Turbo, ie are the spark plug holes different sizes
Yeah, the gunson compression tester (most common) comes with an adaptor which lets you test two different size spark plug holes.
