Actuators
As mine T2 one has packed in from running 19psi is this any good eBay item 270810510626
Says 14psi lift pressure but can be used with a bleed valve to 2 bar
Re: Actuators
That will be more than enough! Maybe a bit too strong, -31 may be better incase you need to turn the boost down at some point??
Re: Actuators
Will have a think about it cheers mate
