Hey all,
After revision of my carb its running too rich, and I cant get it adjusted right.
I can adjust the mixing screw but its ineffective.
The AFR stays around 10.0 - 10.5 while cruising.
On boost is okay, around the 11.5
Idle around 11.5
I thought the mainjet was to large or the a/c to small. so i changed them.
There is now a smaller main jet (first 120 now 100) and larger air corrector jet.
He has now gone from 10.0-10.5 to mid 11 So that's a lot better.
This went well a few days until Saturday.
If I let go of the throttle and pressed the clutch, the AFR shoots to 17 + and the engine stals. When I gear down, the AFR goes to 20+ It backfires like hell and black clouds of smoke come out.
After some adjustments on stationairy and mixture no problem with backfiring or lean afr. but still too rich!!!
I know a 100 mainjet is way too small. So i dont think the problem is on the carb.
Does anyone knows where to look?
Carb specs:
- air corrector 1.2
- 2nd stage 1.2
- 1st stage 1.0
- main jet 1.0
