Just wanted a bit of advice regarding my anti perc fan, i had a replacement fitted as the motor in the fan was shot. The old one would cut in after the engine was turned off as it should. The new one is different as i cant hear it cut in or hear the motor run.
Is there a way of telling if it is working? Should i be able to hear the anti perc fan run?
If it is not working are there any obvious places to look? I know the actual unit is good just thinking about the wiring.
