Results 1 to 10 of 10
    Non-member mike's r5's Avatar
    High Wycombe
    cup mod
    hi guys, im thinking of doing the cup mod, i have read all the threads about it but still dont understand the dangers of bleeding after fuel, i was reading about oil spraying over engine and a few other problems, was wondering if anyone could give me some more info on this, thanks guys.
    Non-member Eugein Offord's Avatar
    Nov 2008
    north surrey
    Re: cup mod
    oil?... i thought the cup mod was for the actuator feed from the carb................it makes little difference on most engines.....i would'nt bother. bruv....................
    Honorary Member Guybrush's Avatar
    May 2003
    Haslemere, Surrey
    Re: cup mod
    Quote Originally Posted by mike's r5 View Post
    Assuming you mean the breather mod. I've got a catch tank in the engine bay.
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    Re: cup mod
    Lol I mentioned lack of cup mod posts to a fellow member tother day. Now we got one, I deem it a good thing I think there's a top article on it, I ran it for years with no issues, but any gains... Debatable
    High Wycombe
    Re: cup mod
    It says in the article on cup mod about if u use a bleed valve it can cause waste gate creep, and fuel vapour. Main reason I'm doing the mod is so I can use my crome lobster neck which don't have the right size port 4 the actuator. Was just wondering if I should do away with bleed valve for this mod. Cheers.
    Mar 2011
    Beaconsfield
    Re: cup mod
    Hi Mike, I can't advise on the cup mod but wanted to say hi to a local member. I haven't seen your car about yet!
    Nov 2008
    north surrey
    Re: cup mod
    next week on rtoc boards............
    Q. is the 285 cam lumpy??
    A. When i took mine out of the box there were lumps all along it................
    May 2003
    Haslemere, Surrey
    Re: cup mod
    IMO get rid of the bleed valve, just adjust the actuator to set the boost. I never see the point of having set up the fuelling for a certain boost level why you'd want to fiddle with it.
    Once you do the cup mod, the boost drops down a little, so you need to wind the actuator rod in anyway.
    May 2003
    Haslemere, Surrey
    Re: cup mod
    Quote Originally Posted by Eugein Offord View Post
    Thats because you got so excited.
    High Wycombe
    Re: cup mod
    ok thanks.
