Results 1 to 19 of 19
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    what is this turbo? t2/ t25??
    Stamped on the compressor housing: Garrett A/R .48 M24 L
    On the turbine housing is: Garrett .64
    The compressor inlet ID is 54mm
    The compressor outlet ID is 40mm
    The turbine fan DIA is approx 45mm.
    Would this unit be a t25.? if so, is it a large or small variant?
    how would this act with a std cam? spool up time etc
    and also how would this act with a piper 285 cam.?
    Re: what is this turbo? t2/ t25??
    Sounds like a T28 of a 200sx S14 turbo, on a 5 gtt will be quiet laggy, .64 rear is large for a 5 even with a cam.
    Get a small shot of NOS in there to make up for the lag and turbo will be fine
    Committee Member
    North West Regional Area Rep
    BluntyR5GTT's Avatar
    Nov 2009
    Stoke-on-Trent
    id second what james says there, if you find it too laggy then i could either supply you with a .49 t25 housing for you to fit or could supply and get it fitted for you
    Feb 2001
    Rohtang pass
    what size housings does a std T2 turbo unit have.?
    im trying to understand the sizes as it confuses the hell outa me.....
    when does a turbo become a full t25? ie what are the minimum housing sizes for it to be classed as a full t25 unit?
    what size was the 220/tomcat turbo unit.?
    Committee Member
    Nov 2009
    Stoke-on-Trent
    Tomcat is. 48 comp housing and. 49 ex housing. Full t25 will obviously have the t25 size housings,core wheels etc
    Committee Member
    Nov 2009
    Stoke-on-Trent
    T2 is. 42 comp and .35 ex housing
    Non-member SCHWARTZ's Avatar
    Wallington south london
    The 200sx turbo has a bolt on inlet and outlet. Il have a look at mine when I get in and see if its m24. Whatever it is like james said the rear housing is very big and will be laggy.
    Edited upload the pic's as attachements now
    200sx T28 is M24 matey
    Pic 1 is T28 200sx S14 cold side Ar.60 M24
    Pic 2 is knackered T28 200sx S14 .64 rear
    Pic 3 Tomcat T25 front ar .48 M27
    Pic 4 Standatd GTT T2 front and Tomcat front
    Pic 5 Standard GTT rear .35 and tomcat .49 rear
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Raj thats a T25. As the guys say 0.64ar will make it very laggy, 5000+rpm so it won't be much use with a standard cam. Switch that housing for an 0.49, if you can find one and it'll be much better.
    Feb 2001
    Rohtang pass
    thanks for the info fellas
    Feb 2001
    Rohtang pass
    has anyone every had a roller bearing conversion done on there turbo? as i see certain companys offer this service!
    Committee Member
    Nov 2009
    Stoke-on-Trent
    roller bearings cost big money but do reduce spool up times especially on t28 powered r5gtts
    Feb 2001
    Rohtang pass
    Quote Originally Posted by BluntyR5GTT View Post
    any idea on the price of a roller conversion fella.?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Ball bearings are about durability. They try and sell you them with the less-lag line, but really it makes sod all difference. They'll maybe respond a bit quicker after a gearchange. It won't come on any earlier than a journal. You can, if the oil is good, get away with murder if you have a ball bearing core.
    Dec 2004
    Aylesbury
    I learnt my lesson on the weekend, don't fit a .64 rear housing Raj. Its far too laggy and spool is very slow.
    Non-member 5teve L's Avatar
    RH12
    Yeah bit big for a little 1.4, I think it's off an S13 200sx as I think thye had the smaller front T25.
    Feb 2001
    Rohtang pass
    yes, the unit i have is from an s13 200sx
    Feb 2001
    Rohtang pass
    regarding my turbo (t25 from a s13 200sx)
    does anyone have any ideas on where i can buy a compressor OUTLET adapter from?
    it has 3 bolt holes.
    Raj...get yourself on www.sxoc.com sign up and check out the classifieds. That's what I did when I needed one.
