Results 1 to 31 of 31
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    GAZ Front Shocks - Assembly
    Right guys, bought some 2nd hand (new) GAZ coilovers.
    Just looking at how to assemble them as they dont come with all the bits I need.
    Heres a pic of the bits I have, some are spares off an old set of AVO's but they don't use the std top cap bearing....
    Does anyone have any advice or better still photo's of how they built theirs up?
    Cheers Ashy.
    Ivybridge
    Re: GAZ Front Shocks - Assembly
    Ashy,
    I have had a number of issues with top mounts over the years, ill upload some pics of my current set up, using helper springs and showing the new conical shaped top hats i got direct from avo, this way all the shocks load is transmitted through the spherical bearings.
    I found that the coilovers never felt right with the standard top hats, and i get lots more feedback from the tyres with this setup. The springs (275lb) are very harsh for the road though, going to go a bit softer for the more broken tarmac at the next few events.
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    these springs are marked up 220lbs so don't know what they'll be like as i'm a bit heavier up front.
    The std GAZ spring retainer looks different to th AVO one (I guess thats the one ur using, more conical in shape)
    Ivybridge
    Ashy PM me your email address and i will send you a pic of the spares i have lying around, if they are any good ill send them to you if you cover post. They are what i was used with a standard set up.
    Al.
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    https://www.rtoc.org/boards/showthrea...=gaz+coilovers
    i dont know if this is any help, im racking my brains trying to remember how mine went together, sorry mate
    Aug 2009
    Newcastle
    Im sure the bearing just sits on the top of this
    Mar 2010
    Blackburn
    There is a picture in the Haynes manual of the shock in exploded view with all the parts in the right order I struggled to put mine together but the pic helped
    Non-member TrixNFlix's Avatar
    Preston
    Just looked at my new phase 1 gaz shocks and I am in the same boat as ashy, I have no idea how to assemble them
    i put mine together and on last week and ive just swapped my engine so there to be fitted again tomorrow i will take a pic and get it on here asap for you guys vof what and how im running my gaz ones
    Preston
    Cheers dude!
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Quote Originally Posted by steer from the rear View Post
    Nice one, thanks
    this is how mine are made up ive the black spring seat which has that round spacer on top, that got a bearing built into it which then sits on top of my lower rubber dounut seat
    Aug 2009
    Newcastle
    Are they phase 1 beacuse mine do not look like that?
    phil
    Russel,
    unless i'm looking at the pics upside down, your shocks look to be wrong? Not that i'm an expert, but all the load is central and not over the spring if that makes sense?
    The black 'cup' needs seating into something, perhaps the doughnut?
    I could be wrong but i wouldn't be happy with them on my car.
    If your using the original top mount setup Ashy, id imagine it will go bearing straight on top of the collar that fits on top of the spring > top hat > rubber donut > top mount then the cup in from the top. Helper springs might be needed to keep the lot together.
    If your wondering about the gaps in the spring and the black cup I've pulled the shocker up to see it all separated but yes I wasn't sure if that's correct but I honestly couldn't built them up any other way, there off the car so now is the time to change it but from what was supplied all I could see is that you replace your standard bearing with the gaz one that's built in to the black cup which is attached to the spacer then the top hat for the donut sits on the spacer? some one ring GAZ lol
    Aug 2009
    Newcastle
    I will whip one of mine of on sunday, if no one has come up with the answer
    Non-member tiff_lee's Avatar
    Glasgow/Lincs
    Looks similar to my spax setup with a black collar sat on top of the spring. I fitted standard assembly on top minus the original coil spring retainer/cap.
    Like this..
    or when I tried fitting adjustable top mounts I bought some small top spring cap things, on the left
    Aug 2009
    Newcastle
    **** i forgot, pictures above are bang on
    Preston
    Right just to confirm guys are phase 2 hubs different to phase 1's? As my phase 1 coilovers are on and the tyres are now rubbing on the springs and adjusters.
    Preston
    Can anyone confirm for me that this is my problem? Cheers, andy
    Ph1 hubs are the same as ph2.
    Preston
    Hmmmmm.... Could I of put the phase 1 strut tops on the wrong way? Otherwise I guess I may of been sent ph2 coilovers? Any other suggestions brigsy?
    Are you suspension holes that go to the hubs above each other or angled?
    Preston
    Above each other on the gaz coilovers, is that ph2 then?!
    Ph2 offset, ph1 in-line.....have a search on here to double check, are your lower arms defo gt items and also ph 1 top mounts will fit either way unlike the offset ph2 top mounts, my problem was I had valver hubs and shafts so had ph1 top mounts on ph2 coil overs on clio hubs and lower arms
    What he said
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Ive got some ph1 compbrake adj top mounts for sale if they would help ya out.
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Got it all sorted, was fairly simple once I took a std shocker appart and had a look. Loads better than the old AVO's I have.
    All the bits laid out.
    Shocker & Spring fitted
    Gaz top cup in place
    Reno Bearing in cup
    Top cup and rubber damper in place
    View from underneath
    Top Plate on
    Cup washer and nut fitted
    Thought it was worth taking a few pics incase anyone needs the info in the future!
    Feb 2015
    Thanks for this. This will come in useful this weekend.
    You see, where else would you get quality info like that from?
