Results 1 to 5 of 5
    Non-member reco's Avatar
    Aug 2010
    Glasgow
    smoking habbit
    as you may know i have the 1.2rl with the gtt engine in place and im using it daily to run the kids to school and nursery
    cars running at 14psi at the mo it was setup by miller for 18psi iirc
    oil pressure is at 15psi when warm
    now it seams to have got into a habbit of smoking when cruising around at slow speeds off boost *(kids in car )
    now this only happens when its warm
    also happens when i take my foot off the go pedal and slightly touch it again on m/way cruising speeds
    i was thinking turbo but on boost i dont see any blue smoke from rear
    ideas up i will check them out
    Re: smoking habbit
    Probably turbo if its smoking when its idling/off boost. You should be seeing 45psi oil pressure at 3k rpm on a hot engine
    Aug 2010
    Glasgow
    Re: smoking habbit
    yip it was t turbo lol can u get a rebuild kit for it
    all info i have is a copy and paste
    Turbo Technics Stage 1 T2 Turbo
    Larger compressor impeller with standard exhaust housing, this uprated turbo will allow use of higher boost than standard giving power figures of 130-150BHP on a correctly tuned engine.
    refitted the standard t2 what psi is standard ?
    and what is its limitations im running it at 12psi for now
    and i was wondering what i could turn it up to ?
    May 2003
    Haslemere, Surrey
    Re: smoking habbit
    Quote Originally Posted by reco View Post
    ~10 psi is standard
    If the carbs been setup for 18psi, why aren't you running 18? Running at 12 You'll be over fuelling heavily on boost.
    With standard intercooling I'd run 15. Better intercooler, turn up to 18.
    Re: smoking habbit
    15psi is the max boost for a standard t2 really
