advice needed on fuel pumps
I'm pretty sure my fuel pump has died as when connecting a battery to it directly its working intermitantly. I'm wondering if its worth fitting an uprated pump whilst the jobs been done. Or should i just put a used standard pump on? The car has a t25 and is running 1bar. Do you guys think uprated is the way to go?
Re: advice needed on fuel pumps
A decent standard pump will do for that boost
:edit: A couple of psi more and I would be looking for a phase 1 pump
Member
Phase 1 Fuel Pump, Bosch Pt No: 0580 464 070
