Results 1 to 10 of 10
    Mar 2011
    Beaconsfield
    Undertray
    Does anybody have one fitted?
    I need to find some fixings for mine, does anyone know the part numbers or have the diagram where they are featured?
    Failing that, anyone have any pictures?
    Thanks
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: Undertray
    hi mate,what do you mean by 'undertray'...battery tray?..
    Re: Undertray
    Under engine tray seen it on eBay. Didn't think it was for the gt turbo more than likely for Monaco but not sure
    THE BAT CAVE
    Re: Undertray
    so its like a plastic sump guard type thingy?....
    Non-member gimme5's Avatar
    Dec 2008
    north yorkshire
    Re: Undertray
    Quote Originally Posted by Renault 5 GT Turbo View Post
    Thanks
    some renault 5's had undertray but not the gt turbo,if the undertray is a genuine renault item then all you need is 4 speed clips and 10mm self tappers,all the subframes have the holes already for the speed clips
    i have picture on dialogy but cant make a link,unless some one else can
    Non-member TNT ANDY's Avatar
    Re: Undertray
    Has anyone done the back (assuming the spare wheel has been removed)?
    Non-member Hoolio's Avatar
    Wallingford
    Re: Undertray
    I thought I had seen a picture somewhere and found it in green Haynes, chapter12 page9. Its got both front and back illustrated but just says later models, assume that means later than the GTT.
    Re: Undertray
    This is interesting. Surprised the drag-racing lot haven't looked into this as surely it would help air flow under the car.
    Also, didn't Russell make an ally sheet for the back end on 'Doris'?
    Non-member rs250nut's Avatar
    Re: Undertray
    I have a 10x5 sheet of aluminium on its way to me
    Dec 2008
    north yorkshire
    Re: Undertray
    Quote Originally Posted by Hoolio View Post
    just looking at renault dialogy and their is a back one it has five fixing points on it
    and its pretty much the same shape as the bottom of the petrol tank,so image it
    sits under there on some later models,no way it go's where spare wheel sits
