Has anyone used these tyres. I assume they are replacing the t1r.
if you can stretch the pounds a bit further try the toyo r1r, better than both the others mentioned
I'd be careful what you fit to your car Marc, t1r on the 5 are great, on the clio 182 utter sh1te..
Clios been amazing on the original exaltos and the current p zero neros....but a t1r won't go near it ever again.
Go on the forums and see what the owners of your car rate.. I'm pretty sure your car will love a set of pzero neros but I also am 100% sure it'll tear them a new ar5e hole.
i need 4 in 225 40 18 so its not going to be cheap . the forum says falken fk452 work well and seem popular and £75 a corner is ok. i know the badass ones will rule supreme but i cant go near £130 a corner.
I have 452s on mine. Not a bad tyre for the price. Quite hard tyre mind, but grip quite well in the wet or dry. Progressive breakaway when you are pressing on.
Got 452s on my Beemer grips well in the wet and great grip in the dry. Rears didn't last too long though
