Page 1 of 2 12 LastLast
Results 1 to 50 of 52
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Bigdurs little car
    Right then, picked up my first ever 5 last Saturday and since I've been planning/scheming what jobs to do. I'm on the lookout for a standard grill and another black bumper. Also toying with the idea of a carbon boot and bonnet.
    First things first, my knee kept interfering with the windscreen wiper stalk so I've chopped it off. Mileage doesn't clock up on the dash and the oil level/pressure gauge is dead too.
    Door cards have been butchered so I'll need to source some nice standard ones.
    I don't plan on fitting a stereo so I thought I'd plug the hole with some gauges, Air/fuel, Boost and Oil pressure (mechanical). Got these on order and waiting for delivery. Unfortunately this bracket I got today from ebay is a flimsy piece of ****.
    I've ordered a standard clock to pop back in here, might need a new boost gauge too as this only goes up to 20psi.
    I need to do something about my seats, they're knackered to start with, that and they're too high, don't go back far enough and I'm over their designed weight limit lol.
    Carb needs a strip and re-build, jetting to suit my engine/boost requirements.
    Finally the body work needs sorting, I'm pretty sure I'll need to sort the sills and various other bits and bobs all round the car before I get it resprayed in black.
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: Bigdurs little car
    looks tidy enough, should clean up nicely.
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    nice little black 5,looks good bud,few niggly bits to sort but no bother,get stuck in.
    an watch them knees....
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Yea, have to say the photos do the paintwork justice, the car needs a respray. Engines good spec though, T28, ported flowed head, low com block, front mount, 285 cam etc.
    Non-member spinner's Avatar
    May 2010
    witham essex
    Looking good mate glad you made it home safe.Sounds like you have big plans for the car already.
    Non-member elcie's Avatar
    Feb 2010
    Southend, Essex
    Nice, Is that johnsons18 old car then ?
    May 2010
    witham essex
    Quote Originally Posted by elcie View Post
    Yeah mate was one of my fives only got one now .
    Dec 2004
    Aylesbury
    Quote Originally Posted by bigdur View Post
    Standard comp mate
    Once got carb back to how it should be will be good runner.
    burton on trent
    real tidy car that mate,
    https://www.rtoc.org/boards/showthread.php?t=20699
    also if it interests you , the above £30 the pair .
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Well just got home from work and my 2mm needle valve and AFM have turned up, having the boss welded in the downpipe Friday so weather permitting I can start tuning/winding up the boost on the weekend.
    Door cards look a good price, I'll have to go check the condition of my plastics though, and price up speaker grills too.
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    I have a few problems today, got my afm hooked up and running 22psi I'm getting 12-12.5 on the gauge but if I boost in a gear and change up the next gear boosts for a fraction of a second then the engine seems to loose power. I can't see the afm meter go up though. I'm presuming it's because I need to drill out the 2nd stage, just strange it boosts well in the 1st chosen gear. Carb is standard apart from a 2mm needle valve. To get to 22psi I wound the boost up slowly about a psi or 2 at a time.
    Next issue is idling, I've had it apart 3 times and everything is clear. The mixture screw seems to do sod all though so I've ordered a new one, on idle the afm is reading upto 18 then going off scale, cruising it reads 13.5-15.
    Last issue is connection my oil pressure gauge, I can't seem to see where to connect it, I can only think this is due to having a T28 hybrid or perhaps it because I'm being dim.
    Dec 2004
    Aylesbury
    Thats just knocking into little lean on full boost mate, you'll need to take 2nd stage out little more. Its 1.2mm at moment take it out to 1.3mm.
    With changing gear you saying it pulls away fine but then second later you loose all power?
    Carbs not quite standard, 2nd stage is 1.2mm and a/c is 1mm, standard venturi and main jet.
    As its reading lean this will explain the erratic idle, worth trying a new mixture screw although check if the bottom hasn't snapped off the old one.
    On the bottom of the oil feed line you'll se the pressure switch, thats where you'll find the connections
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Ah I thought you put it all back to standard Mark, it was confusing me a bit as to why it seemed to be fueling so well on high boost, around 15psi it was reading in the 10's.
    As for the oil gauge connector I'm really being dumb I think. I can see the braided line going into the top..... would a photo help? I can easily snap one.
    The loss of power, it doesn't seem to want to rev past 6000 then if you change up and boot it again its like its holding back.
    Where roughly do I need to be looking for this connection point?
    Dec 2004
    Aylesbury
    Follow the braided oil feed hose all way to union on the block then at the base you will find a pressure switch (big dome unit), thats where the wire wants to connect to.
    Did you not see what the afr's were doing when it decided it didn't want to go past 6k?
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Sorry Mark, should of said it's a mechanical oil gauge. Does that matter or is the position the same?
    As far as I could tell the a/f gauge didn't change, just had big hesitation. Time for beer and meat now, I'll have another look tomorrow.
    Glasgow
    Sounds like its emptying the carb at 6k ..i had this when i borrowed reco's carb from his clio gtt ...im sure someone on here will tell you how to sort this
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Good news, got the car idling great at 14.7 ish, had to clean out the idle valve a coupe of times, on boost it runs great in 4th/5th and doesnt lean out at all. The 2nd stage was already 1.3 so I went up to 1.4mm.
    A couple of quick questions if you don't mind, oil pressure gauge is fitted, on tickover I get around 12.5psi, 2500rpm 40psi and 4000rpm about 46psi. Do those figures sound healthy? I do plan to change the oil and filter next weekend as I'm not sure whats in it tbh. I believe 15 or 10/40 is recommended?
    Next on my worry list, on tickover if I rev the engine I get light blue smoke from the exhaust, can't notice it running and not on boost either. Thing is I had m filter off yesterday and cleaned/re-oiled it with a K&N kit. I think I may have been a bit keen re-coating the oil, could this well be the source of the smoke? It didn't do it before though I've messed with the carb a fair bit too.
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Small update, the smoke issue was a blocked breather so I've made up a catch tank, fueling is really getting there now, the car really flies and power is nice and smooth on boost, It seems I was flooding it a bit which was causing it to bog down and hesitate when boosting through the gears.
    I'm not exactly sure of what psi I'm exactly running atm as my gauge only goes upto 20 and the needle goes past that! I'd say around 23-24, new 30psi unit is on order.
    New air filter fitted, these are going for £40 at the moment on ebay which I thought was good value.
    I've stripped the interior right out as it wasn't the best condition, boot floor is good and solid as are the floors mainly, just a couple of small spots on the passenger floor where it looks like someone has jacked up on the pan and a reasonably large bodge-job to the drivers floor as shown below. The sills are completely shot both sides but I was expecting that so I'll be learning to weld before next years MOT!
    Gave the fluids a change, a bit of a worry the gearbox fluid that came out was around a litre and a half but the capacity was around 3 1/2 when I refilled it so it was a good job I changed it!
    New seat and boost gauge next week then I'll go for an IanS air intake temp gauge. Still on the lookout for a roll cage if anyone fancies shifting theirs.
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Not fantastic news yesterday, I had her up on some ramps at the body shop and we took the kit and bumpers off. Not too great tbh
    Sills are badly rotten as are the rear bumper mounts, the jacking points are gone and there have been some 'repairs' near the front jacking points which my mate just shook his head at. Also needs a couple of plates to the floor pans.
    For the moment I'm going to push this into the corner as I've found another rolling shell (black ) and perhaps take a look at it when I've got more time on my hands as we're expecting our baby next week!
    Priority now is working out how to do engine transplants, I'll be searching the boards for hints and tips...... One thing I've learnt from repairing old valve amplifiers, take lots of photos as it's coming apart!
    Good on you, keep going
    Btw, unless you want more headaches in the future, turn the boost down a bit so you can see what psi you are running until you get that 30psi gauge. When that arrives I wouldn't go over 22-24psi for everyday road use if you want any sort of longevity at all.
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Thanks, I've got the gauge but obviously I wont fit it till I've done the engine swop now, the car won't be used for everyday, the plan is to drive to trackdays etc and the occasional weekend spin. Once its all back together I'll probably spin down to Marks to get him to do the final carb tweaks as I still have the occasional hesitation issue.
    Does a local member have a hoist by chance? Reading up, some of you make these jobs sound so easy/
    Non-member 5 turbo's Avatar
    Mar 2011
    Shes sounds Pretty Solid fella... an its a black un,will look sweet when its done
    Happy Mig-ing
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Some progress this weekend.
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Double post
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Changed over to a T25 today and fitted my Willy wheels, anyone know where I can get center caps? I think it looks rather nice now.
    Jul 2011
    Burton on Trent
    Looks very nice mate! I think willy wheels look great on a 5
    Hows the T25 driving wise?
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Very nice. You can buy willy centre caps from Renault ( not cheap though ) failing that just look on ebay
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Cool, I'll get a price from Renault as the main dealer is only 10 minutes from me.
    T25 wise the lack of lag suits me better, really good fun to drive out on the road.
    I took it for a spin and was getting about 8psi boost so I wound the rod out about 10mm and tried again, 12psi this time, AFRs about 10.8-11, tried to wind it some more and the rod seems to spin on the spot now. Have I got it on it's limit?
    I'm wanting about 20psi or so tbh, so not sure whether I'll need another actuator or a bleed valve. More money.
    Pic of where the rod is now, any advise would be apprecfiated as always.
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Hold on, I might be being a bit daft, if the rod spins on the spot I'd need to hold it with some grips.
    I'll have a look tomorrow and report back but 99% sure I'm a tit.
    Moderator
    South East Regional Rep
    LiamR's Avatar
    Dec 1998
    Medway, kent
    Love the wheels mate-they look ace
    burton on trent
    ledgend
    i was verhappy with my t2/t25 on 18psi mate..
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    I'm an electrician and hifi dealer mate, not a mechanic
    Aug 2004
    yeh your a tit...
    Non-member tubbyG's Avatar
    Dec 2010
    thats looking awesome
    really suits the willy wheels
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Anyway it's 'you're' not 'your'. You are Raider-gtt and I claim my prize.
    Aug 2004
    thats my bovard face
    Oct 2004
    Somerset
    car looks good bud....sure ive seen it before.... and like that , good to see it coming along bud, keep up the good work....
    Non-member mike r5 gtt's Avatar
    Jul 2009
    car looks brilliant and loving the willi wheels
    burton on trent
    yep i really like it with them wiliams wheels, so much im tempted to sell on my turbines.. hmm
  41. #41
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Cracking car matey
  42. #42
    Non-member Gttnutter's Avatar
    Oct 2005
    Amersham
    22-24 psi on t25
  43. #43
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    That's the plan mate, I'm going to change my fuel pump 1st as I've a feeling it's a bit tired then wind it up.
    Popped into the Renault dealership today to see about Williams center caps, he told me I'd need the part number printed on the back of one. Could someone let me have it please or does anyone know if a cheap alternative will fit say off ebay?
  44. #44
    Oct 2004
    Somerset
    ill look tommorow jack on mine
  45. #45
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Great thanks, he wasn't too helpful though I suppose it was a Monday morning.
  46. #46
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    His holy one send me the details on the willy center caps, rang Renault and no march.
    He asked for the clio number plate so i googled for an image of one and gave him that. Part found! No idea whether they will turn up gold or black though and £20 each, payment upfront.
  47. #47
    Looks well mate! I miss my Williams wheels, they suit the gtt's well
  48. #48
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Really pleased with it now, a few jobs to do........
    New Spax setup to fit
    Remove gearstick and refit correct way round
    Campus pulley
    Campus filler
    Fuel pump
    Rev limiter
    New Varley redtop battery to fit
    Battery isolator to dash,
    Some bodywork to do
    Campus window winders to fit
    Perspex front windows to complete the set
    Rollcage door bars to paint
    Clocks playing up
    Carb re-build kit to do
    Alarm to remove
    Boost to set with possible carb tweaks
    Repair/tidy up dash.
    Should keep me quiet at the weekends when the weather picks up.
  49. #49
    Member
    Turn The Log tuning
    bigdur's Avatar
    Mar 2011
    Malvern
    Mot time today then going to see a body shop about a few issues... Wish me luck!
  50. #50
    Non-member IvanClio172's Avatar
    Good luck mate....let us know how you get on.
