My Williams has started to leak water in through the plastics on the roof where the electric sunroof switch is. The rubber around the sunroof is ok and appears leak free so I am assuming that the drain is blocked..?? The heater in the car is also getting very weak possibly due to the water build up? The drivers side floor is also getting very wet.
Can someone confirm if this is the problem and how I go about fixing it..
Many Thanks
