Hi can anyone tell me if these are the correct 2mm needle valve for a 5 ? (thread wise etc) Thanks
http://cgi.ebay.co.uk/Schwimmernadel...item518f55682b
Take the old one apart n drill it. Seals better if you drill from inside out.
yes that is the right one and works aswell
Ive got one in my hand but cant work out how it comes apart?
Cheers mate so you only drill as far as the pin? Its only a spare so will have a practice when my drill bits turn up.
I forgot to ask is it straight in at 2.0 or is it worth trying 1.8 and 1.9?
may be better opening the hole up slowly as less chance of getting a bad burr and not sealing properly.
Go straight for 2mm if your drilling out the standard, done properly it will seal fine.
The hole in the ebay 2mm needle was under 2mm when i tried to fit a drill bit in mine, i drilled mine out to 2.1 & it still seals ok so might be an option if you need more fuel.
