Results 1 to 10 of 10
    Kent
    On a diet.......
    My sprint car is apart again.......more dieting!!!!
    Kent
    Re: On a diet.......
    ....while its apart, out with the old track rods....and in with the new!
    Kent
    ....and fit the megajolt........
    Loose Bolts Tuning stuTHC's Avatar
    Dec 2005
    Leeds
    Stripped
    How come you haven't just removed the interior plastics rather than just attack them with a hole saw?
    Non-member BriC's Avatar
    Dec 2005
    Quote Originally Posted by stuTHC View Post
    Stripped
    You read my mind
    Kent
    Stripped
    Regs say interior trim to remain......
    Dec 2005
    Leeds
    Thought that's what it must be.
    To what degree do they hold you to that rule thou? i notice the carpet and some of the interior trim is missing, and you've got pretty savage with that hole cutter, is that about as much as you can get away with?
    what about engine spec (although i know in hillclimb thats a massive area) can you ditch the alternator for instance for an easy weight save?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    I know someone that once carved all of the metal work and innards out of their rear seats - bench and back support - so they were hollow!! "looked" fine, not to be sat on....
    bracknell
    Quote Originally Posted by Matt5 View Post
    get that sound proffing off the front floor
    brickwall
    Kent
    I run in class B2, Roadgoing production.
    So, in a nutshell......inside.......carpets can go but sound-deadner must stay. Interior trim stays in.......its a very long read so................
