has anybody experimented with the above on a 5 gtt, or any renault model, i know the 5 is as aero dynamic as a brick,but there must be a reason why renault fitted them to the turbo 2 maxi production racer (rwd)and the clio maxi (fwd), also Tony H from prima used a clio type spoiler on his hill climb/type events renault 5gtt.
would these not help give more high speed stability and better traction,more for track use on longer high speed straights and higher speed corners,
thinking of perhaps fitting an adjustable rear wing to my car and making an adjustable alloy splitter that i can bolt to the front subframe with some tie rods attached to the splitter and bolted through the front slam panel something like this
http://www.carbonmods.co.uk/Products...NSPLT001.aspx#
http://www.carbonmods.co.uk/Images/p...l-tie-bars.jpg
but without the expense, and perhaps the flex from a carbon fibre type, where an alloy plate or fibreglass covered ply splitter might work better /not flex
thoughts anyone
