Page 2 of 2 FirstFirst 12
Results 51 to 74 of 74
  1. #51
    Non-member ioshi_s_golf's Avatar
    Oct 2010
    Manchester/ Bulgaria
    Re: R5 gt 1.4t swap to b18ft
    That would be ace if you could matey.
    Keep up the good work its really coming together now
    Thanks bro
    Will try on wednesday not to forget to make the list with all the wires.
  2. #52
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Quote Originally Posted by ioshi_s_golf View Post
    Thanks bro
    Top darts.
  3. #53
    Oct 2010
    Today was the firts time taking the 5 out with the MS did only 10 miles because the altelnator it's not charging the battery. Will see why and on friday will go mapping again
    here is a pic of the down pipe
  4. #54
    Oct 2010
    Update from the last hour
    I have 2 bad news
    1-st The injectors finish at 4K rpm and they hold till 5k Rpm and till 5k rpm the afr gauge shows 12.0. So I put the rev limiter to 4800 rpm .
    2-nd The clutch slips on 5-th gear betwen 60-75 miles. After that it doesnt slip. But i hope soon will put new clutch with ceramic plates.
    1 Good news
    with the td04 and the new exhaust manifold i got 0.7- 0.8 bar at 2800 rpm.
  5. #55
    What injectors are you using matey?
  6. #56
    Oct 2010
    200cc The std injectors, need to buy bigger injectors. But first need to buy the clutch and after that the injectors.
  7. #57
    Oct 2010
    Ok guys need help about the thickness of the ceramic plates because i'm going to make new clutch.So i need to know what thickness i need to buy. So the thickness of the ceramic plate is 3.25mm which is 0.12 inches and the next thickness is 3.5 which is 0.13 inches.
    Which one should i buy ????
    Cheers
  8. #58
    Oct 2010
    Some update from the last few mins. I order the ceramic plates for my new clutch, and they will arrive on wednesday . The thickness what i need is 3.25mm
  9. #59
    Oct 2010
    Time for update
    Decide to take everything from the engine bay to clean it and to respray the engine bay.
    So some pics from today.
    Before
    After
    Still need to do a bit of work on it to shine more but tomorrow maybe.
  10. #60
    Oct 2010
  11. #61
    Oct 2010
    It's time for update
    Finaly with new paint in the engine bay
    Before ...
    Ready for paint.
    The result
    Need to respray few other things and will put all things together
  12. #62
    I love this project
  13. #63
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    So much fresher with the bay done, the down pipe looks good to, keep at it
  14. #64
    Oct 2010
    Quote Originally Posted by philg View Post
    Yeah it looks much better resprayed , can't wait when i put everything in the bay . When everything is in, need to finish with the mapping of the car because the injectors were too small. So will get bigger ones.
    How many miles you guys recommend to wait till i start pushing the car with the new clutch? I think 100 miles will be enough for the clutch to bed in.
  15. #65
    Oct 2010
    I think it's time for update
    Also i fit bigger injectors 315cc and fit the ceramic clutch. Yesterday i beat audi s3 with 2 or 3 cars. I was with my brother in the car.
    I'm running now at 1.5 bar
    On this video we start from 0-160++ and i was with to much wheel spin. http://www.youtube.com/watch?v=1QWs1_NvFdY
    On this video we did flying start with the audi S3 and you will hear that my car R5 just after putting 3-th gear start to work not very good. This is because the fuel in the tank got a bit low but after that was ok. And still beat the audi, and in front of the peope i just overtake him and after that im making this distance 2 or 3 cars
    http://www.youtube.com/watch?v=azrW6FgrmIs
    I hope on 9-th of June to go to a Drag race and time attack and will see how it goes there
  16. #66
    Oct 2010
    Hi guys
    what is your opinion to keep using the b18ft engine and to do some head work, bigger throttle body, Ep cam, bigger injectors ( I'm using ( now 304cc) and bigger turbo ( i'm using td04) and i think to buy td05 16g or 20g, or t28. Or to buy f7r engine with head from f7p and to use the td04.
    At the moment my set up is:
    Mega squirt, td04, tubular manifold, 304cc injectors. The boost is set up to 20 psi.
    What do you think it will be better ?
    Cheers
  17. #67
    Dec 2004
    Aylesbury
    Hi guys
    Cheers
    You know what my opinion is mate
    If you did decide to go F7R/P then i would upgrade the TDO4 turbo as that seems abit too small for the engine.
    If your not after a massive amount of power then i would stick with the Volvo engine, the major part of work is done and you seem to have a fair bit of power under your right foot now. With a few more upgrades you could squeeze bit more out of it but if you only after abit more then this will be the cheaper option
    Did you ever take it to drag strip and see what it done?
  18. #68
    Oct 2010
    Yeah i went to the drag strip i had problems with second gear. When i'm racing and when i try to put second gear just it doesn't work. After the second or 3-th try i can select second gear and with this problems i still beat renault laguna 3.0 v6 207 hp. Just to say i use the long fork conversion Here is the video from the race
    http://www.youtube.com/watch?v=8R7ER...&feature=share
    Well i don't know what power i have now. But since the race with the audi S3 i get use to the power and now it feels like that it's not fast. The power what i'm woking forward is 250hp or a bit more. I'm quite happy with the gear box it feels good on the drag and time attack. The gearbox code is jb3 009
  19. #69
    Dec 2004
    Aylesbury
    What time did you do on the strip mate?
    I think with the Megasquirt you might be able to get to around the 250bhp with what you got but you will need to do a bit more to it (deffinately change cam) to reach it
  20. #70
    Oct 2010
    16.7 sec
  21. #71
    Dec 2004
    Aylesbury
    16.7 sec
    Do you know what terminal speed it was?
    Come on you should do better than that!
  22. #72
    Oct 2010
    From this what i remember i did 175km/h which is 109 mp/h
  23. #73
    Dec 2004
    Aylesbury
    Thats not bad terminal speed mate, i'd say roughly 225bhp going on that speed
  24. #74
    Oct 2010
    Yeah i think it's not bad as well, and i think that i'm a bit over 200bhp but no idea how much. The problem is it feels slow .
    So this is the reason why i want to get some more Bhp.
    p.s So what do you think guys it will be better to go for new engine or to keep going with the b18ft ??
