Results 1 to 10 of 10
    Non-member 5teve L's Avatar
    RH12
    Alt belt size...
    Anyone happen to know the number from halfrauds or the size for the alt belt ??
    Lost mine last night, kept coming off @ high rpms (not hard when it's wet) & then I totally lost it
    Will have to look to see if it's on straight as well as I don't want it to keep coming off
    Non-member WADDIE's Avatar
    Cheshire
    Re: Alt belt size...
    not sure on the part number for halfrauds but here's a tip for ya...check the top alternator bracket that there is no marks on it where ya tighten the adjustment, mine used to slip all the time so i milled a new flat on it and used a bigger spacer to clamp the bolt to the bracket and it never came off again! other peeps use a bolt behind the belt to stop it flicking off some peeps on here may put a wee piccie up of there's!?
    OE GTT is 1180 or is it 1175 x 10mm width knobled underneath
    RH12
    It's ok, Halfrauds actually came up trumps with the right belt !!
    On closer inspection the alt & waterpump deffo weren't lined up, looked out by about 5mm loosened the bracket & re-tightened it pushed over & it looks much better now.
    Just need to test it now....
    Ivybridge
    Steve, also worth checking the alternator bushes for wear/ovality. They are cheap from a renault dealership and a common cause for belts coming loose under high load.
    Glad you got it sorted matey
    Dartford
    Check the bottom pulley is on the right way round too... It has an arrow on it
    RH12
    I'll check that but I don't think I had that off Dave... something else I can blame on James if it is
    RH12
    I may order some up just to be sure
    Bottom pulley is on fine matey, i never lost or had ay probs with alt belt's on that lump must be alternator fixings
