Xenon heigh adjustment problems in Laguna
I have problems with my Laguna automatic height adjustment.
Following things I have noticed or tested:
- No fault codes (so front side sensor should be ok)
- When I start engine it does adjustments correctly
- After 2 min of running lights are pointing to ground...only six meters away from car. If I restart car then automatic adjuster corrects lights to right level, but again after 2 min those pointing to ground.
Is there any basic "screw" that can be used to adjust headlights higher?
My car is Renault Laguna 2, phase 2
Re: Xenon heigh adjustment problems in Laguna
Are the height adjuster rods ok? One in on the rear axle near the brake lines and the other is on the front left lower arm. Matt5
Both are ok. I checked those yesterday.
