Results 1 to 9 of 9
    burton on trent
    damn door decided it wont close
    well , after having no probelms before, my passenger door has decided it will only close onto the first latch today, no matter how much slamming you do..
    I presume its going to be the catch inside the door thats at fault, is this a common problem, and would i be right in saying replacing that is the solution
    Leeds & South Yorkshire Area Rep
    Loose Bolts Tuning
    Robbo's Avatar
    brighouse
    Re: damn door decided it wont close
    door pins maybe??
    Non-member modfather's Avatar
    in the park next to sewage works
    if you do go down the road of needing another door catch i got 1 sat in a door in my garage
    Non-member rat1's Avatar
    Feb 2009
    The dog house
    it might be the pin on the door pillar has moved (the bit it locks on to ) loosen it an move it out a bit . my driver door had something similar,remove the lock clean it with carb cleaner or something cover it in oil,worked a treat for me
    Spray a load of wd40 into the latch and work it open/closed with a screwdriver, will sort it.
    Dec 2009
    west midlands
    As Brigsy said loads of wd40 and work the lock in and out and it will free it up, mine did this not to long back I'd gone and got a new lock and before I fitted It I tried It so i now have a spare.
    Mat
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Check the door hasent dropped either.
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    its well worth actually taking the lock totally off an submerging it in degreaser,then fresh grease/oil etc (helps the solenoids to),you can do all this and it will help but id be looking at the door pins/hinge and the locater on the piller for wear and movement.
    Feb 2009
    colne lancashire
    mine did the same, after hours of messing around still no joy, i just fit a new lock easy to do and was sorted,
