Is this supposed to dangle down in front of the alt??
Also the relay is encased in a waterproof round cover, does the relay come out of it to replace like for like, or is it a complete unit you have to replace??
nope, there was a popper for it and its either meant to clip just behind the grill clip, look for a hole, or along the slam panel.. thats where i have mine now as my clip broke..
Did'nt think so, read in a few old posts that theres was just danggeling, great something to do on the weekend now
does anyone know if the relay comes out of the circle waterproff thing???
Let me see you wiggle it -addigroove. Old school reference there.
Is this the right part for the fan relay???
http://www.halfords.com/webapp/wcs/s...egoryId_165562
Does the fan use a standard 4/5 pin relay or is it some propriety renault one?
I assume if you're looking for a new one the current one isn't working then?
yes looking for a new one, the one i took out was a 5 pin, had the relay out and its all corroded/buggered. The part does'nt say renault on it, says mixo???
I was thinking more along the lines of pin configuration, meh it's probably the same I can't remember it was ages ago I binned my loom.
You can use just a 4 (or even a 5 pin) pin relay wired to the alternator and fan switch to operate the rad fan, that way it is independent of anything else.
Are you using the anti perc fan or fog lights?
If not and still have the relays in place they are the same as the fan relay, all relays in under the bonnet are the same.
i'll get my go go gadget arms out and try and hear the foglight clicking
