Results 1 to 17 of 17
    Non-member garya's Avatar
    Dec 2009
    clydebank
    Renault 5 with starlet engine
    Non-member tubby5's Avatar
    york
    Re: Renault 5 with starlet engine
    As it says in the title I had loads of boost leaks which resulted in an 101mph trapspeed
    all the leaks are sorted now.but it needs the map tweeking as it's running leaner as soon as it hits full boost
    burton on trent
    Possibly a new route forwards for the r5 transplants ?. What level of work was required to get said engine , into the r5?.
    A guy in burton once managed to get a 2.0 redtop into a r5, but i only ever heard of it going for mot and failing, and that was the last of it.
    york
    There's quite a bit of work involved.custom brackets for engine mounts,front crossmember cut and moved forward,driveshafts cut n shut(Toyota ones slot into the Renault shafts) no gear linkage rod to do as it's on cables,I also cut the scuttle away for easy access to everything at the back of engine,new alternator arm and bracket made as the origanal sits very close to brake servo.also the drivers side chassis leg was slightly modified.
    Non-member 5teve L's Avatar
    RH12
    piccies of progress ?
    york
    The only pics I have are of how it looks now(completed).
    I will post some up though when I get chance.
    Non-member benj88's Avatar
    Mar 2010
    Legend.
    Non-member Rob1980's Avatar
    Nov 2006
    Ashford
    Should we now add this thread to the current Glanza/Starlet v Renault 5 GT Turbo starting this is best? It will really please the new guy who joined just to bring back that thread....
    york
    a few pics as promised
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    love the build...rocker cover is awesome
    york
    thanks,got the old man to thank for that
    Dec 2009
    clydebank
    Holy jobby farts that looks awsome gd work
    Non-member Logg's Avatar
    Well done dude looks very tidy.
    EFI & 16v without a heavy lump up front must drive very nice.
    Committee Member
    North West Regional Area Rep
    BluntyR5GTT's Avatar
    Nov 2009
    Stoke-on-Trent
    this has to be a perfect conversion for the r5 as long as you have the time n money to do it.
    RH12
    Was it an easy conversion to do ?
    Looks right at home in there
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    i like this conversion alot
    i think i may give this a thinking over in the future. but id want to know exactly what work is envolved and which/what way to go about doing the conversion.
    i think about it............ and then i think just go with a b18ft
    Apr 2009
    On the back roads
    Quote Originally Posted by benj88 View Post
    Legend.
    Quoted for the truth......
    What mods on the engine? What ecu? And what dash gauges you using?
