accelerator pump problem!!!
Hi guys, I have a small dribble of fuel coming out of the accelerator pump hole on the side of the carb?? I have rebuilt it and fitted it to the car and turned key on and noticed it?? I thought this was ment to have no fuel coming out of it as the pipe plumbs into the carb top??? any thoughts anyone???
Re: accelerator pump problem!!!
you mean out the bent brass tube? im a little confused
sorry i mean out of the pipe on the side of the carb where the pump arm is? it is where the pipe tees of and goes into the carb top. cheers
its running now and no fuel is leaking it was the diaphram which had a hole in it. just one query though just i have a small dribble of fuel from the little brass pump nozzle in the carb on ideal???
did you set up the accelerator pump jet after you put it all back together? 5mm drill bit etc...
hi, i never adjusted the nut or undone it a uncliped it from the butterfly?
