Results 1 to 8 of 8
    International Area Rep
    Jul 2009
    Hungary
    Another carb question
    When I'm reving my friend's GTT from 2000 till 5000 with a 2/3 throttle (in this case boost is around 6-7psi) first as the acc pumps a bit it gets around 12-12,5 but soon after leans out till 16-16.5.
    If I rev the car with wot than it is around 13-13,5 all the range. (std. boost around 10psi)
    Is this normal from a std. carb or shall I check something?
    Thanks again.
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: Another carb question
    is this just revving the engine in neutral? as i think the engine would need to be under load to give you a proper reading.
    Jul 2009
    Hungary
    No, in 3rd gear.
    sounds like its a bit lean all over then. theres articles on here that explain what the readings should be at, at what rpm, throttle position etc...
    Jul 2009
    Hungary
    I've read trough all articles but I've only found readings at WOT and I haven't found readings for half or 2/3 throttle.
    Maybe I'll try a smaller a/c.
    Tipton
    you need to make a note of the vacuum readings in relation to the afr readings.
    Jul 2009
    Hungary
    There is no additional turbo gauge in the car only the one in the instrument panel. So I only know pressure at the carb top.
    Jul 2009
    Hungary
    I've also observed another abnormal behaviour of this car.
    Cruising on a flat road in 5th gear around 3k rpm, boost is around 2-3psi @carb top and the AFR readings are a near constant high 14s than after a while suddenly low 13s. And not only for a moment.
    I have already checked the fuel flow. 1bar at the FPR, running the pump for 40s and it pumped around 1,2l. And the flow seemed to be constant.
    Could it be an air leak? But where?
