Results 1 to 22 of 22
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    vtec. vvt. variable valve timing. etc
    apart from hondas v-tec and i-vtec systems is there any others system that works just like it.?
    toyota have the vvti i think? what else it there? and more importantly do all the variable valve systems work in the same way.?
    im more and more liking the v-tec system and the way it delivers its power.
    ive not come across anything thats feels quite like the vtec systems.
    just wondering did the clio/r19 16v's have variable valve timing? as the hondas from the same era did.?
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Re: vtec. vvt. variable valve timing. etc
    BMW has VANOS, but thats more electronically controlled.
    Tipton
    nissan has variable cam timing too....the 200sx's have it, whereas the silvia turbo didnt....
    the clio 172's do too.
    think mitsubishi do - Mivec or summat like that?
    its not that uncommon, its just that some manufacturers make more noise about it that others.
    my gtt had variable cam timing...it only happened once on one run when the vernier pulley bolts slipped to max retard.
    Oct 1999
    Bournemouth
    Quote Originally Posted by Sparkie View Post
    Feb 2001
    Rohtang pass
    but do they act in the same way? i say this as ive been in a few vvt cars and they done seem to have the kick that the honda vtec's produce!
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    renault variable valves work through a camshaft de-phaser which fail quite often and you can hear them rattling backwards and forwards. typical renault. The pulley adjusts via oil pressure either advancing or retarding the timing.
    Sep 2005
    Parkgate Cheshire
    hondas vtec works via oil pressure too but this raises a 5th bucket for the cam to act on and open another valve in each cylinder. i think its another inlet but im not sure.
    Vtec is for whimps, give me a turbo anyday, but if ya want some detailed info on Honda's vtec system take a look here
    http://www.vtechuk.com/
    cheshire
    Vtec increases the inlet valve duration. It isn't all that tbh. The rover vvc is much better as it is 2 stage where the vtec only works on one stage ie high rpm.
    Feb 2001
    Rohtang pass
    dont be daft vtec is brilliant. a vtec + turbo power would be awsome i think
    cheshire
    Quote Originally Posted by raj View Post
    Not as awsome as the rover k series vvc
    Quote Originally Posted by dj13 View Post
    Er Rover bought the rights to the Honda B16 engine back in the late eighties, rebadged it K series and screwed up its reliability
    Feb 2001
    Rohtang pass
    yes it is. to be honest ive not experienced the rovers vvc so cant comment.
    are there any similar sized rover engines with vvc compared with the hondas vtec?
    i wouldnt mind seeing how..lets say a rover 1.6/1.8vvc goes up against the honda 1.6/1.8 vtec.
    The Meagane 225 and 230 F1 have variable valve timing
    Feb 2001
    Rohtang pass
    ah yes indeed. they old rovers did come with the honda engines.i never knew which ones though.!
    Salford (manchester)
    http://www.youtube.com/watch?v=AcT_Z...eature=related Thats how the D16 SOHC is on our civic but we can control the solenoid to what we like, well once its running. Bit old skool that tbh.
    The porsche 3.6 has vvt + vario cam looks a good bit of kit on them. All the 3.4s just have vario cam and all Boxsters same + 968 3L 16v vario cam. Need the new 3.8 to fail so i can pull it apart.
    Blah who wants cam shafts, bring on the days with valves are controled by solenoids. think of what power and timing or whatever you could make then....
    Oct 2003
    solonoid valves are already don ein the bike world just need for it to pass on to cars, cant find anyinfo on the engines tho. some of the superbikes they use for racing at the mo have it. as far as i can tel they dont have a camshaft atall, all computer controled solonoids that fire open the valves as and when, full time vvt
    Tipton
    just more electronics to go wrong.....
    Non-member Kenobi's Avatar
    Jul 2006
    Leicestershire
    My Colt CZT which is a 1.5 turbo is a Mivec.
    Theres talk over at www.CZTOC.com of using a Renault 5 Turbo shell to build a track weapon.
    Jap powered nutty french magic.
    Honorary Member RichR's Avatar
    York/Selby
    Quote Originally Posted by Kenobi View Post
    The Colt does share a gearbox after all, so that shouldn't be too much work to mix and match bits.
    Jul 2006
    Leicestershire
    Quote Originally Posted by RichR View Post
    What ya mean by share good buddy?
    York/Selby
    Not the new Colt - the old Colt. Gearbox is based on the Renault JB series I believe.
    (of course I could be imagining it, it is Friday afternoon after all).
