Page 1 of 2 12 LastLast
Results 1 to 50 of 75
    1.8 16v turbo or 172 turbo????
    Ok I am consdering doing the R19 1.8 16v conversion into my R5 (If I keep the 5 as have taken a deposit but not sure I can't part with the car may have to tell the bloke the engine has blown up can't sell) but want to maintain the use of my Radtec Alloy Rad and Intercooler setup as I will in the future be putting a turbo on it and wanting to re-use this kit.
    I am wondering how much space do you still have @ the front when the engine is all in place so I can get an idea as to how to make the kit fit? (Suppose i could always cut the crossmember and weld.
    Also has anybody tried a VNT that was made for the R5 and is it any good on the 1.8 16v engine? or is to small?
    Sorry if the questions are a little simple but that is just me Simple as
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: Clio 1.8 16V
    From what I've seen when we converted Ricardo's old gtt, you can just about get a radiator in there, let alone anything else.
    For sure you'd have to lose/modify the front crossmember as to accomodate the Radtec setup.
    Re: Clio 1.8 16V
    Not that much space due to the inlet manifold.
    Normal 16v rad fits in just. Ive just had to cut the cross member as re weld a new angle iron bar across to strengthen as the fan was too tight against the hoses behind the rad so fan is now in front. Not sure what sort of size the intercooler is but im guessing if you dont mind modifying the bumpers then i dont see why it couldn't fit i guess, I just prefer the original look at the front now.
    Re: Clio 1.8 16V
    As for the turbo, my gt28rs spools up under 2k revs and pulls all the way up to the limiter. Think the problem with the VNT is going to be the mapping side i seem to remember somebody saying due to the air flow and things like that.
    Re: Clio 1.8 16V
    Cheers for the advice, going to see if I can source a decent engine for decent cost
    May 1996
    Pie & mash shop
    Re: Clio 1.8 16V
    Why not start off with a better base? (namely a 172/182 engine)
    Re: Clio 1.8 16V
    Hmmmm 2.0L I remember seeing Ashy's @ Nat Day wish I got a closer look now. Looks like he may be getting a pm
    May 1996
    Pie & mash shop
    Re: Clio 1.8 16V
    Aii, and don't forget Scoff's monster as well.
    Re: Clio 1.8 16V
    Many thanks for all the advice defo going to be sending a few pm's about
    Jul 2003
    Re: Clio 1.8 16V
    COUGH VAG 1.8 20V Turbo?? COUGH
    Re: Clio 1.8 16V
    Should go to doctors to see about that cough
    Re: Clio 1.8 16V
    I did like the drive in the VAG clio @ Nat Day when Dale took me for a spin, but I was trying to get the money together for Minty's clio VAG but doesn't look like that will be happening as I just can't let the 5 go yet. So I am wanting to do some kind of conversion over a peroid of time but stick with a Renault engine.
    Mar 2004
    Coventry
    Re: Clio 1.8 16V
    If you don't want the vag route you could always got 225 engine if you want to stay Renault
    May 1996
    Pie & mash shop
    Re: Clio 1.8 16V
    I must've somehow amazingly missed out on all these drives of the vag clio...
    Re: Clio 1.8 16V
    Quote Originally Posted by Duncan Grier View Post
    I remeber reading a thread about Matt C Tinworm doing the 225 conversion be interesting to see what it is like once completed.
    Looks like I may be holding out to see the completion of his project before I make descision on which engine.
    Oxfordshire
    Re: Clio 1.8 16V
    I'd say that it's a lot easier to turbo a 172 than it is to fit the 225.
    Re: Clio 1.8 16V
    FAIL
    May 1996
    Pie & mash shop
    Re: Clio 1.8 16V
    Likewise for Duncan's VXR, and Alex's CSL...
    Re: Clio 1.8 16V
    When turboing the 172/182 what clutch and flywheel to peeps tend to use?? Do they stick with GTT??
    Re: Clio 1.8 16V
    Ive kept with the gt turbo one even though im using the 172 gearbox. However will be looking at 215mm flywheel/clutch set up when the time comes as they will be better at holding it. But the valeo clutch is holding for the time being so dont need to worry at the moment
    Re: Clio 1.8 16V
    Cheers for the info Dale, what about using the R5 clocks? is this possible
    Re: Clio 1.8 16V
    Depends on what gearbox you are after. If you go gt turbo gearbox you use the gt turbo clocks. f7p/f7r/clio 172 phase 1 gearbox you use any clio/19 16v clocks which with a little modifying can fit in the 5 dash clocks space (ive got them in mine) if you go phase 2 clio 172 or 182 engine your stuck with clocks you will need to look elsewhere
    Mar 2004
    Coventry
    Re: Clio 1.8 16V
    LOL you can have a go next time we are on track sir just not the ring there is none of that jap taxi 4wd saftey stuff going on in our cars well maybe there are options in Al's?
    Sure Alex will let you rag it round the ring
    Seems although we have been to mulitiple track days and events together we still have not experianced each others cars lol. I have never even been a passenger in yours yet
    Jul 2003
    Re: Clio 1.8 16V
    Oh you should of said mate, you could have had a drive...... oh no.... hang on i forgot you sold your band & was running the Creche instead
    Anytime geeze!
    Mar 2004
    Salford (manchester)
    Re: Clio 1.8 16V
    Best thing with the 1.8 16v the lump is cheap, so if you get it wrong and score a block or what ever there wouldnt be to much of a fuss to sort it out....
    Non-member sphinX's Avatar
    Feb 2005
    Telford
    Re: Clio 1.8 16V
    What kind of reliable power are you looking at with a turbo charged 1.8 16v block? What benefits for you get from the 172 block with its higher price?
    Non-member rs250nut's Avatar
    Re: Clio 1.8 16V
    Is this a better base to start with? Why not use an F7R? Megane or williams
    Re: Clio 1.8 16V
    F7R is 150bhp standard and on an old engine
    172 and 182 are 172bhp and 182bhp. However problem being as Scoff found out torque is too much on the 2l engines
    Feb 2005
    Telford
    Re: Clio 1.8 16V
    too much torque never!
    Non-member BlueFish5Gt's Avatar
    Greece
    Re: Clio 1.8 16V
    I thing that the bore and stroke of an f7p are better for a turbo conversion as it revs higher than an F7R.
    Re: Clio 1.8 16V
    Quote Originally Posted by BlueFish5Gt View Post
    I can see why people go for the 1.8 due to cost, but the williams head is better and with a bit of machining and a 1.8 crank I think you have a better engine. What is the bore and stroke of the f4r? is it closer to being square?
    May 1996
    Pie & mash shop
    Re: Clio 1.8 16V
    Why stress the engine by rev'ing it high though? I'd start off with a 2L base, which then gives you scope for a torque'y and/or more power overall setup.
    As ya man said above, without even touching the engine you'll be starting off with 170/180hp.
    Re: Clio 1.8 16V
    Where I need to run 6psi to get that over that amount.
    Mar 2004
    Re: Clio 1.8 16V
    I think it depends what you want from the engine... weather it be drag or track etc for the torque... but very true basic point....
    Also if your blowing a 172 it wont be 172bhp once you drop the comp for the charge dont forget, unless you run pony boost..... (ps im not saying pony boost is slow by all means) just a point....
    But the 172 is going to be the best head out the lot for the job so yes its going to be the best lump to turbo.....
    May 1996
    Pie & mash shop
    Re: Clio 1.8 16V
    You're always gonna get more power, regardless, if there's a bigger displacement to start with. And unless I'm wrong, and by all means correct me if I am, I haven't seen nor heard of any F7P based turbo conversions setting the 1/4 mile alight.
    As for the 172/182 comp' ratio, fair enough, you may have to drop it a point or 2 to run some boost through it, but it's not like you're gonna be dropping the base power down to 137hp (or whatever the F7P standard hp output is).
    Re: Clio 1.8 16V
    Mart its not all about 1/4 mile though. Track days is also where it should be.
    Mar 2004
    Re: Clio 1.8 16V
    For sure your going to make more power with a 2L with out a dout... But then peeps would soon need to invest in proper gearbox mods with the extra torq for drag i would have thought (if used for that).. Scoffs 1.8 172 route seems the best way (for drag) and big boost...But a 2l stroke lower boost car would be brutal on a track...
    And no there arnt many f7p turbos setting fast 1/4 from what ive seen...
    Blahhhhh C1J power rules anyway
    May 1996
    Pie & mash shop
    Re: Clio 1.8 16V
    I know mate, it was just a tongue in cheek reply back to Rob's comment about whether you want drag or track performance from the engine. My point was that it shouldn't really matter for either scenario if you start with a good base for power.
    May 1996
    Pie & mash shop
    Re: Clio 1.8 16V
    Exactly
    Mar 2004
    Re: Clio 1.8 16V
    Exactly
    And heres me in process of the D16 civic team car wheres my coat......
  41. #41
    Re: Clio 1.8 16V
    LOL not wrong there Andy, its a bit of a challenge. It should be ready to fire possibly this weekend delays mainly been due to having a dodgy ecu. Its all in, wired and only one sensor away from the big turn on! Fingers crossed it works.
  42. #42
    Re: Clio 1.8 16V
    when peeps talk about cost, I bought my ph2 172 engine with all ancillaries for £450 I recon by the time I sell the power steering and air con bits it'll stand me closer to £350.. I've seen similar for the 1.8 16v for about £200 so we're not talking a huge pricing difference I think the cost comes in when you start looking at the engine managment and costs associated in turboing it engineering and fabrication (if if turboing is the route)
    Depends on the ultimate goal, I must adit there's a lot more 1.8's knocking around than 172 engines at £450
  43. #43
    Re: Clio 1.8 16V
    Erm, obviously you haven't tried breaking a renault 19. Can pick them up for 200-300, sell alloys on 100, selling seats on (if leather) weigh car in, cost equals nothing plus you know the f7p lump is running because you can hear it running. You then also have all the hoses, ECU, wiring, to plug and play. No worries about modifying the bonnet for it to fit. 172, if your going NA you either need to get the ECU programmed in to get rid of the immobiliser, you also need to make sure the gearbox is the right one else the speedo wont work. Most engines are from the later models, so do you go for gt turbo box? Theres pros and cons for both engines.
  44. #44
    Re: Clio 1.8 16V
    Ok just a little update on this, i have been able to source an early type 172 engine with the cable throttle and ECU that has been fully unlocked + all the other gubbines pipes, loom,.
    At present i am only going to go N/A but in the near future will go turbo.
    Now I am just a little unsure if this is a good move from my modified C1J, as the Mrs's keeps tellimg me that if i do it i will only regret it and she is normally right when it comes to the 5? what do you guys think I should do C1J or the 172 in N/A (for now)?
  45. #45
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Re: Clio 1.8 16V
    i would have thought the c1j would be quicker/nippier and the 172 more rev happy with more scope.
    depends exactly what your after.
  46. #46
    Re: Clio 1.8 16V
    The problem is you can't just bang the 172 in and go racing. It takes ages to get to a point where you actually trust the conversion. Also the good thing with the cij is its cheap to fix. Pop a head gasket on the 172 and its a good £200 + for the parts. You will also have to lower the compression when you consider turboing it and to get the best from it all and aftermarket ecu is a must. But its a great conversion and worth the hassle.
  47. #47
    Re: Clio 1.8 16V
    Decision made 172 Turbo conversion it is.
    Car will be coming off the road hopefully over the next couple of weeks whilst I remove the C1J and obtain / collect the 172 parts needed.
  48. #48
    Feb 2001
    Rohtang pass
    Re: Clio 1.8 16V
    could we have some sort of database telling us of all top renault breakers in the country.?
    thought it may help with folks who want to source parts for spares for conversions!
  49. #49
    Feb 2005
    Telford
    Re: Clio 1.8 16V
    Selling any parts on the C1J?
  50. #50
    Non-member car.crash's Avatar
    Aug 2006
    Re: Clio 1.8 16V
    james keep us updated on the conversion. once im finished with 5's i would mind getting a 172 and putting a blower on it.
