actuator pipe
witch is the best way to put actuator pipe. at top of carb to actuator or bottom of carb to actuator is there any difference in boost.
North East Regional Rep
Re: actuator pipe
Pretty sure boost at carb top is 4 psi more than at carb base. Someone will be on shortly to correct me if I'm wrong
Member
Re: actuator pipe
Mine has about 2psi difference from top to bottom of carb but i think it varies with the set up of your carb ie group a etc.
