Results 1 to 15 of 15
    Non-member richi's Avatar
    manchester-kinda
    dropping engine
    is there a guide on here for what to do as in taking everything out, my cars getting ready for a respray so thinking might go balls out and do engine bar whilst im at it
    Tipton
    Re: dropping engine
    there used to be a guide on the old site...not sure where it is now.
    manchester-kinda
    Re: dropping engine
    yeah i can remember reading it lol
    manchester-kinda
    Re: dropping engine
    anyone?
    Jun 2001
    Telford
    Re: dropping engine
    If I can do it then anybody can!
    Just need to get the driveshafts out, with the drivers side you might have some hassle with the split pin and my method of draining the gear box oil by pulling the driveshaft out isn't everyones idea of smootheness (PMT f0' life y0 )
    Then you just need to be removing the water hoses to start getting yourself some room to see whats connected, then its the mounts and the fuelling side of things, got to remember stuff like the gear lever connector thingy, but it is really easy
    Non-member BriC's Avatar
    Dec 2005
    Re: dropping engine
    When you say.. 'dropping engine' do you mean dropping it all out from the subframe? Or lifting it out with the engine crane? If you're lifting it with the engine crane (which is what I did for my paint job).. Just basically do what Marcus said. Split pin on the driveshaft isn't too hard.. dunno what he is whinging about , but it can be hard lining it up when you are putting it all back together.
    Also - Haynes has a write up in the green R5 manual which is good as a check list. Simple enough really
    manchester-kinda
    Re: dropping engine
    was thinking about taking it out from underneth, have a good idea of how to do it as i did my mate with him, was after a check list really so i could just follow the same order when putting the thing back in
    Non-member Adam L's Avatar
    Feb 2003
    SW London
    Re: dropping engine
    I'll do an abreviated check list...
    Undo everything
    Take engine out
    Masterbate with oily hands.
    Non-member OUTLAW's Avatar
    ENGLAND
    Re: dropping engine
    Non-member GTphil's Avatar
    Re: dropping engine
    is there not a guide in the haynes manual?
    Jun 2001
    Telford
    Re: dropping engine
    I have only done it taking the engine out from the top, not messed about with the subframe etc.
    All you need to do is take your time and take lots of pics as you go and you will be fine
    Re: dropping engine
    ohh you mean taking it out the bottom! more or less the same realy, although if you unbolted the top mounts the whole lot would just drop down once the subframe bolts are undone, obviously making sure before hand that all the cables e.t.c are disconnected. heater matrix hoses, gearbox selector, engine earths,throttle/choke/clutch cables, intercooler/hoses, rad/hoses, vac pipes, and make sure the weight of the subframe/engine is supported then lift the car off. I seem to remember me haz an scoff placeing my car on the edge of the ramps then dropping it down untill the subframe was on a trolly, removing subframe bolts then just lifting the car off!
    easy peasy!
    this is the pikey method tho! lol
    manchester-kinda
    Re: dropping engine
    sounds fun think i will get my disconnecting on then lol, just make sure dont drop subframe on legs check
    Jun 2001
    Telford
    Re: dropping engine
    Quote Originally Posted by richi View Post
    Ah go on be an amusing read if you did
    manchester-kinda
    Re: dropping engine
    take one for the rtoc team lol
