Results 1 to 8 of 8
    Jun 2009
    israel
    Boosting my R5 1.1 Lit.
    two years ago, i have bought my current R5 TL 1.1 Lit. witch was dropped in the back yard of an old man, apparently not in use for years.
    i offered him to buy it, he was happy for helping him to get of the car. here starts my affair with my lovely converted GT5.....
    at first i was thinking to swap the engine with the clio B sport engine, later on i knew that there is a turbocharged renault engine for the R5, and gone for it....
    i saw a guy driving a R5gt, (he is one of rtoc members, "cokigtt"), and he has helped me to convert it to GT-turbo, "cokigtt" has supported and helped me, and still does....
    After has been resprayed with a 1.1 liter engine:
    Add Tires & Wheels, size 15"
    After two months I began to see waves on the paint, so was decided to paint it again, here is a picture
    Plaster work like we see, with more waves and a paint made by a brush, in the end we started all the job all over again and resprayed it
    after the paint has done properly, i took it to "C.H. performance", a renault tunners in israel
    Unfortunately the process of improving the car was conducted without the photos, but I will explain in detail what has changed in the car:
    - At first we have made the complicated changes in the Block of a 1.4 engine, like Gt-Turbo cylinders and pistons , new bearings, uprated Head Bolt, uprated Head Gasket .. All parts are of the R5 GT Turbo.
    - Carburetor R5GT
    - polished and ported Head of R5GT turbo engine replacement of Valves including .
    - Rebuilding the exhaust manifold turbo r5gtv
    - turbo td06 of impreza.
    - cat back 2.5" exhaust pipes.
    - FMIC custom made
    - Forge dump valve
    - A renault kango diesel Gearbox relatively long ratios
    - Clutch of the renault clio rsi 1.8 liters 200 mm.
    - swaping a Camber Kit, Lower Arms, Steering Arms. Front Subframes all is OE parts from clio 1.8RSi.
    - front and rear Brake Kits from renault clio RSI.
    - Replacing rear axle of clio rsi.
    - Wallbro 255lph Fuel Pump, including replacing the fuel hoses 8mm.
    - Adjustable fuel pressure regulator.
    - Because of the Carburetor not provide a suitable fuel mixture with 1.5 bar, I decided to add two Fuel Injector 220 CC, including self-management,
    - Radiator of a renault 19 1.8 liter, including Cooling Fan Kit.
    Only that so far
    After installing all the wires for the audio system, the system was dismantled again, and come to Step General upholstery.
    It's me
    The sunroof assembly, taken from Mazda 323 2003
    It was fun to work all night
    now some photos after the mess
    After that I think that it looked like any renault 5, so I decided to replace Wheels and Tyres. I chose lenso muse wheels.
    Current photos
    Videos
    http://www.youtube.com/watch?v=jDvkYTLOGg4
    http://www.youtube.com/watch?v=uAeLcyK5G2Y
    These days I'm starting a new project "two turbo engines"'ll fill you in later. "
    Non-member Dudders's Avatar
    Hersham, Surrey
    Re: boosted my r5 lt 1.1
    brilliant, just shows what enthusiasm can do
    Non-member Kenobi's Avatar
    Jul 2006
    Leicestershire
    Love it. Good thread, keep us updated.
    Jun 2009
    israel
    North East Regional Rep HULK's Avatar
    Aug 2009
    harrogate, North Yorkshire
    Do I spy a wooden steering wheel???
    Mar 2010
    Romania
    how much HP you think it has??
    Jun 2009
    israel
    I did dyno test the score was 200 HP at 1.5 bar.
    Mar 2010
    Romania
    Can you put bigger pics with the engine bay,please?????I'm curios how you made the intercooler track.I want to put a bigger one to my car and i must use the same track.And how you do your carb top plenum???tnks
