aye but theres a lot of con artists in the motor trade tho
There is a lot of con artists in EVERY business.......Politicians are a good example.
Calipers are the best part of £100 each new x 2 plus 1 hour labour.
The discs are roughly the same as the above.....
Bleed the brake system PROPERLY £10 in fluid plus 1/2 hour labour.
A tyre fitted and balanced? God knows....
Adjust headlamps.....seconds to do.
Were they quoting to fix oil leak as well? If so, thats steam clean off the local area and fix the leak....
Soon mounts up if you break it down doesn't it?
The good thing about doing it yourself is you can spread the cost.....I don't trust second hand brake parts if you go that route.....
