Results 1 to 11 of 11
    Wirral
    is 1.4 bar too much forastandard t2?
    i have alloy i/c, stainless exhaust up rated carb jets, low tempkit. run car at 0.8 of bar normally just step up manual boost controller and in car valve open is 1.3-1.4 bar........... 2 much?
    Non-member Slim's Avatar
    Sep 2009
    NW London
    Re: is 1.4 bar too much forastandard t2?
    well put it this way... it will defo shorten the life of it...
    Dec 2004
    Aylesbury
    Quote Originally Posted by bigdikky5 View Post
    Thats about 20psi, think thats abit more then i'd be running through a standard T2.
    Wirral
    i use car very little, just pootle round once a month. im only gonna be running full boost maybee for 1/4mile and track fun. how much will it shorten the life??
    Sep 2009
    NW London
    ummm by about 90%???
    Dec 2004
    Aylesbury
    Its not about how long the turbo will last its how effective it will work at that boost pressure, at that pressure not too well.
    I recon charge temps will be quite high as your be working the turbo too hard, best off either running slightly less boost or fitting another turbo with a larger front end on it.
    Sep 2009
    NW London
    k well.. for wat its worth... my bro ran a t2 for a few months at 17-18 psi.... then 20 but then it broke... but it definatly goes faster lol
    Wirral
    cool.will bring bit back abit to 17-18psi... like 1.2 bar
    Committee Member
    North West Regional Area Rep
    BluntyR5GTT's Avatar
    Nov 2009
    Stoke-on-Trent
    miles to much for a t2 you want 16psi max really as been stated the charge temps will be quite high and the turbo wont last long, if you want go more than 16psi upgrade the turbo fella
    Non-member patrick's Avatar
    Jan 2010
    Zebbug (malta)
    i ran with 5th injector for fuelling,straight through exhaust,straped intercooler and 15psi,that was fine i tried to take the t2 to 17psi but the inlet temps where running so high that the first pull on the dyno was registering 170bhp and the second pull was nose diving to 120bhp same boost because of heat soak in the std intercooler give it some time to dissipate and the power would go up once more. so 20psi def to much even with alloy intercooler!!
    Quote Originally Posted by BluntyR5GTT View Post
    Been a topic many times. 16psi max on the standard T2.
