First thing to help assess the engines health is a compression test, as long as the readings are within 10% of each other, its a good start.
New plugs, leads, dizzy cap and rotor arm. Plugs wise, the standard plugs or Ngk b8 evx's...or even the Campus plugs
Flush and refill the cooling system, make sure it's doing it's job...is the thermostat ok and is the fan cutting in as it should? Is it cooling properly and generally good all round ie not losing water and pressuring etc
New engine oil, pretty much anything other than just a mineral oil...
Find a turbo that'll suit your needs...
Ask someone to help tune the carb for boost...20psi requires a bit of fine tuning as some jetting works well on some engines and not so on others.
I've only been a GTT owner for a few months, that's what I've learned and it works well
Maybe upgrade the intercooling...carb freeze will **** you right off
