With the aid of CAD drawing or 1:1 scale is it possible to work out a fixed degree of negative camber by say enlarging the diameter of the hub and/or hole on the damper. For example the diameter of the hub hole is 20mm, enlarging it to say 20.5 or 21.3mm would give a fixed permanent negative camber of 1.5 degrees (figures picked at random)
Was thinking it would take the guess work away when using 'corrector' bolts, you'd know it would always be a certain degree of camber. Or am i talking nonsense
