Results 1 to 8 of 8
    Non-member Kenobi's Avatar
    Jul 2006
    Leicestershire
    Mk1 Clio
    Ok, so if i was buying a 5 I would know what to look for. However I have just purchased a mk1 clio and im wondering if there are any problem areas to look at.
    On a 5 i would check boot floor and boot sidewalls. Is this a good place to check on a clio?
    Yes Yes I have bought a car without seeing it. Its a none runner and hasnt cost me the earth so its not a worry.
    Non-member f0xy's Avatar
    Warrington
    Re: Mk1 Clio
    Sills and arches mainly!
    Sep 2009
    Derbyshire
    Re: Mk1 Clio
    yeah, rear arches and sills are the main areas, structually they can also go on the floor too though this is harder to spot.
    Other areas that are easier to fix are the boot, under the doors, the inner front arches and the slam panel...
    Jul 2006
    Leicestershire
    Re: Mk1 Clio
    Thanks guys. :ho:
    Glasgow
    Re: Mk1 Clio
    Check for ....
    rust on sills
    holes in the floors
    inside the arch area's of the engine bays rust aswell
    rear arche's (ones on yours should be fine as dave got them replaced previously).
    Rusty boot lids.
    Boot floor also.
    And the usual places for rust ...like round the window rubbers and scuttle panel.
    Hope this helps
    Kent
    Re: Mk1 Clio
    Is it a 16v Clio?
    Sloppy steering wheel (lots of play before steering wheel makes the wheels move) usually means the rubber has gone in the joint between the column and the rack.
    Manual opening roofs are leak prone.
    You say its a non-runner......flat battery or something else?
    Kent
    Re: Mk1 Clio
    Ah, just checked your profile.....I'm guessing its the blue project you are talking about.....
    Jul 2006
    Leicestershire
    Re: Mk1 Clio
    Yes mate but thanks. Im looking for things that need fixing.
