Results 1 to 10 of 10
    Non-member The Pink Panther's Avatar
    Cork, Ireland
    Cgb oilcooler sandwich plate prob..
    Ok i bought a FMOC from cgb recently which i'm very happy wit but i went to fit it and i'm slightly confused..i jus fitted a recon head etc.. Fitted all d bits..Went to start..ticked over perfect den it pissd oil outa d sandwich plate between d block.i hav it pretty tight wit a gasket (used one from an old oil filter) < which could b d prob.. But i'm wonderin on this plate there is 3 ports 2 on top and one on d side wit a thermostat.i currently hav it in the top two flowin tru d cooler wat i'm wonderin is should i hav one in d thermostat port and this is causeing a build up of pressure and leakin out the gasket or would it matter? Any advise or suggestions would b greatly appreciated.
    Non-member minty83's Avatar
    Nov 2005
    Shrewsbury
    Re: Cbg oilcooler sandwich plate prob..
    do you mean cgb
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    I fink it mite b d gasket dat u re used
    Dec 2004
    Aylesbury
    I'd put a new gasket on the sandwich plate mate, once they come off the block old gaskets never want to seal up properly.
    Apr 2002
    duz yoo speeka da inglesh? looooooololololololololzz!!!1!!!11!
    Nov 2001
    Hogwarts
    Aiiiiiiiiiii
    Cork, Ireland
    Yes cgb sorry, also sorry about d spelling i'm using my phone here an i iz used 2da tx ;-). Ya thats wat i'm thinkin..none came wit the kit so thats the best i could do also the nut securing the plate back is quite hard to grip wit a socket to giv it that extra squeeze.ill just have to try that. Cheers lads
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Hi, I keep the Sandwich plate Oil Seals in stock, if you get stuck.
    Cork, Ireland
    yup turnes out it was just the seal! thanks for advise! and phase i 16 v turbo for the offer.
    Trader
    Jan 2001
    Morden
    You are welcome.
