Windscreen wiper problem.
Since i bought the van the wipers have never returned to the park position unless i do it manually, is this a wiring or relay fault? Also which relay is for the wipers?
Also my van hasn't got the intermittent setting for the wipers, there either on fast or faster which can be highly annoying, is this because of the diesel low spec wiring harness?
Trader
Re: Windscreen wiper problem.
its usually a fuse blown....also feeds the cigarette lighter illumination and the like....
i used to have a campus and that didn't have intermittent wipe so it might just be the spec. it was well annoying.
Checked the fuse earlier, was popped changed it & intermittent wipe works & wipers park ok.
Thought all was well until i armed the factory fit alarm & it goes off all the time with that fuse fitted, Im assuming there's a short in the wiper park circuit?
